Is it possible to define the following layout:
A row consists of:
Column 1: Cell A and Cell B stacked (vertically)
Column 2: Cell C (height of C = height A + height B)
Thanks.
Hi Dunken,
Please ignore the above post.
I hope I got your idea right. Here are the styles I created to achieve the label layout you're describing:
<igc:XamDataPresenter.Resources> <Style TargetType="{x:Type igc:LabelPresenter}" x:Key="rowspanLabel"> <Setter Property="Template"> <Setter.Value> <ControlTemplate TargetType="{x:Type igc:LabelPresenter}"> <Grid> <Grid.RowDefinitions> <RowDefinition Height="26"/> <RowDefinition Height="26"/> <RowDefinition Height="26"/> </Grid.RowDefinitions> <Label Content="My Additional Label" Grid.Row="0" /> <Label Content="My Custom Label" Grid.RowSpan="2" Grid.Row="1" HorizontalContentAlignment="Center" VerticalContentAlignment="Center"/> </Grid> </ControlTemplate> </Setter.Value> </Setter> </Style> <Style TargetType="{x:Type igc:LabelPresenter}" x:Key="hideLabel"> <Setter Property="Visibility" Value="Collapsed" /> </Style> </igc:XamDataPresenter.Resources>
Then I applied these 2 styles to the 2 labels as follows:
<igc:Field Name="name" Row="0" Column="0" > <igc:Field.Settings> <igc:FieldSettings LabelPresenterStyle="{StaticResource rowspanLabel}" /> </igc:Field.Settings> </igc:Field> <igc:Field Name="department" Row="1" Column="0" > <igc:Field.Settings> <igc:FieldSettings LabelPresenterStyle="{StaticResource hideLabel}" /> </igc:Field.Settings> </igc:Field>
Please let me know If this has helped you.
In order to achieve the layout you're describing, first you need to set 2 properties of FieldLayoutSettings as follows: AutoArrangeCells = "Never" and AutoGenerateFields="False". Next, you should define the desired field layout - you need to define the position (row and column) and the rowspan(colspan) of each field. For example:
<igc:XamDataPresenter.FieldLayouts><igc:FieldLayout><igc:FieldLayout.Fields><igc:Field Name="name" Row="0" Column="0" /><igc:Field Name="department" Row="1" Column="0" /><igc:Field Name="salary" Row="0" Column="1" RowSpan="2" /><igc:Field Name="email" Row="0" Column="2" /></igc:FieldLayout.Fields></igc:FieldLayout></igc:XamDataPresenter.FieldLayouts>
Hope this helps.
OK, I just figured it out:
<igDP:FieldLayout.Fields> <igDP:Field Name="A" Column="0" RowSpan="2" /> <igDP:Field Name="B" Column="1" /> <igDP:Field Name="C" Row="1" Column="1" /> <igDP:Field Name="D" Column="2" /> <igDP:Field Name="E" Row="1" Column="2" /> </igDP:FieldLayout.Fields>
B, C and D,E are stacked now. Instead of having a label for B and C itself, I would rather like to have a label for B, C together... Can I do that? Even better, I would like an additional label like a header of a header --> "Column A" "A", "Column B" "B "C", ...
