115
Customize FieldChooser captions in XamDataGrid.
I need to provide a meaningful description for each field in the Field Chooser of XamDataGrid. How can I do this?
Mihir.
  • 138253
    Hello Mihir,
    It has been a while since you have made your post, in case you still need support I will be glad to assist you further. I suppose the other community members can benefit from this answer as well. I have been looking through your post and I created a sample project for you with a custom separate ToolTip for each Field in the FieldChooser. Basically I copied the default style for the FieldChooser and add a ToolTip in it and using a Converter I return different values depending on the Field’s Name.
    xamDataGridFieldChooserToolTip.zip
