I have a simple requirement. I assign a Obseverable collection to a xamGrid. Then I want to hide all the columns (maybe around 20 columns). Afterwards, I would like to show some columns in a given order (maybe 5-6 out of 20 columns). These shown column order is driven by xml configuration file.
I tried using the ActualPosition / Move methods from the fourm examples.. but none of them work. Can someone give me a working example. Thanks
public void HideAllColumns() { try { if (this.grdData.FieldLayouts.Count > 0) { foreach (Field fld in this.grdData.FieldLayouts[0].Fields) { fld.Visibility = Visibility.Hidden; } } } catch (Exception ex) { } }
public void SetColumnPosition(string columnName, int position) { if (this.grdData.FieldLayouts.Count > 0) { this.grdData.FieldLayouts[0].Fields[columnName].Visibility = Visibility.Visible; this.grdData.FieldLayouts[0].Fields[columnName].ActualPosition = new FieldPosition(position, 0, 0, 0); } }
When I make a call to hide and then SetColumnPosition, there seems be gaps between visible columns. I am new to wpf, but this functionality was very simple in windows grid. Please suggest what might be wrong in the above code
I am just checking if you got this worked out or you still require any assistance or clarification on the matter.
Sincerely,DimiDeveloper Support EngineerInfragisticswww.infragistics.com/support
