240
How to redirect cell click event to another cell in the same row?
I have a simple grid with two columns and I am trying click event to be redirected to the neighboring cell, so edit would be activated.
Right now when I click the left cell, I get this:
When I click the left cell, the result I am looking for is this:
I am not sure what would be the best way to approach it. Should I write a custom template or handle the event in the code?
Thank you.
  • 30945
    I am just checking if my post was helpful for you.
    If you require any further assistance please do not hesitate to ask.
    Sincerely,
    Krasimir
    Developer Support Engineer
    Infragistics, Inc.
    www.infragistics.com/support
  • 30945
    Verified Answer
    The reason that you are getting this result is that the data type of the Age field is string and you are using XamNumericEditor. The XamNumericEditor is used for editing numeric data and you can avoid this behavior by:
    1.       Changing the property’s type that the Field is bound to, to numeric data type.
    2.       Set FieldSettings’ EditAsType property to some of the numeric data types. For example:
    <Window
            xmlns:sys="clr-namespace:System;assembly=mscorlib"
                                                    <igDP:Field Name="Age" Label="Ages">
                            <igDP:Field.Settings>
                                <igDP:FieldSettings
                                    EditAsType="{x:Type sys:Int32}"
    If you require any further assistance on the matter please do not hesitate to ask.
    Sincerely,
    Krasimir
    Infragistics, Inc.
  • 30945
    If you want to use XamNumericEditor in your cell I can suggest you to set FieldSettings’ EditorType property to XamNumericEditor. You can do that as follows:
    <igDP:FieldSettings EditorType="{x:Type igEditors:XamNumericEditor}">
    </igDP:FieldSettings>
    </igDP:Field.Settings>
    </igDP:Field>
    By doing so you will keep the functionality that you need and you will have XamNumericEditor in your cell. You can also add this:
    <igDP:FieldSettings.EditorStyle>
    <Style TargetType="{x:Type igEditors:XamNumericEditor}">
    <!-- Change editor's setting if needed -->
    </Style>
    </igDP:FieldSettings.EditorStyle>
    in the FieldSettings for the Field that you want in order to change the XamNumericEditor as you need.
    Sincerely,
    Krasimir
    Infragistics, Inc.
