In outlook 2010 I can use F6 to cycle through the main window elements, including the ribbon. When the F6 key takes me to the ribbon it also displays the key tips for the ribbon.
I want to do the same in our application, how can I programatically cause the xamRibbon to display the key tips?
I have created a feature request on this issue.
I have sent your feature request directly to our product management team. Our product team chooses new feature requests for development based on popular feedback from our customer base. Infragistics continues to monitor application development for all of our products, so as trends appear in requested features, we can plan accordingly.
We value your input, and our philosophy is to enhance our toolset based on customer feedback. If your feature is chosen for development, you will be notified at that time. Your reference number for this feature request is FR13427.
If you would like to follow up on your feature request at a later point, you may contact Developer Support management via email. Please include the reference number of your feature request in the subject and body of your email message. You can reach Developer Support management through the following email address: dsmanager@infragistics.com
Thank you for your request.
Currently there is no property or method that will put the ribbon into keytip mode. For now you may use SendKeys method to send an F6 or F10 or Alt key.
I will go ahead and log this as a feature request for you.
This does not answer my question. I am trying to emulate the behavior of the F6 keystroke in Outlook 2010. This cycles through the main sections of the UI including the ribbon, so at part of my logic for this I need to be able to activate the ribbon key tips from code.
Using F10 on XamRibbon you can display key tips which is similar to MS Word or MS outlook. Below forum post also discusses similar issue.
http://community.infragistics.com/forums/p/22434/81880.aspx#81880
Please let me know if this is what you are looking for. Please do not hesitate to contact me if you need further assistance.
