Is that possible Column Chooser button display in HeaderPrefix area of XamGrid in WPF?
The XamDataGrid has a built-in functionality for showing the ColumnChooser button in the HeaderPrefixArea. Here you can see how to set it:
http://help.infragistics.com/NetAdvantage/WPF/2012.1/CLR4.0/?page=xamDataPresenter_Display_the_Field_Chooser.html
Stefan - Is this functionality built into the WPF3 dll's? If not would this same be compatible with a XamDataGrid created with the WPF3 Data Presenter assemblies? I'm attempting to implement a column chooser similar to this sample you included on an older project.
Thank you for your post. I have been looking into it and I created a sample project for you with the functionality you want to achieve. Basically I added a Button to the ContentTemplate of the RowSelectorHeaderCellControl and called the XamGrid’s ShowColumnChooser method. Please let me know if this helps you or you need further assistance on this matter.
