490
Binding to a collection which holds multiple other collections
I have a xamdatagrid binding to a collection of “Nodes”. Here are my custom classes
    public class Node
        string name = string.Empty;
        public string Name { get; set; }
        ObservableCollection<Node> child = new ObservableCollection<Node>();
        public ObservableCollection<Node> Child
            get
                if (child == null) child = new ObservableCollection<Node>();
                return child;
            set { child = value; }
        ObservableCollection<Forecast> forecasts = new ObservableCollection<Forecast>();
        public ObservableCollection<Forecast> Forecasts
            get { return forecasts; }
            set { forecasts = value; }
    public class Forecast
        public List<Load> Loads { get; set; }
    public class Load
        public int Value { get; set; }
I would like to bind my grid to a collection of Nodes. I have to generate my fields dynamically. I first create a field for my Node and Child. Then once I try to expand a child that doesn’t have any other children I would like to display the values in my forecasts collection.
        private void xamDataGrid_RecordExpanding(object sender, Infragistics.Windows.DataPresenter.Events.RecordExpandingEventArgs e)
            if (e.Record.HasChildren == false)
                Field forecast = new Field();
                forecast.Name = "Forecasts";
                forecast.Label = "Region";
                e.Record.FieldLayout.Fields.Add(forecast);
When I do this I get 2 blank rows with just the names of the Child field and Forecasts field. If I expand the Forecasts row I can then see the values in my forecasts collection.
Is there a way to display the Forecasts values automatically and not display the Child Field name? I tried to remove the Child field but if I do that I lose all child fields in the grid and can only see my top level node…
