455
WPF Browser Application and Global assembly Cache
Dear all,
Today's project is to create a WPF Browser Application with a standard C# .NET program inside.
What I have done so far:
  • Setup a Server with the program and all dependencies installed on it (including Infragistics.Win).
  • Created a WPF-BrowserApplication with VS2010 as a certified Full-Trust-Applicatio
Everything works fine on the server and also on other machines having Infragistics.Win installed. But if I run the Application on a naked maschine (only Framework is installed), i get an error: Assembly Infragistics2.Win.UltraWinExplorerBar.v11.2 have to be installed in GAC to run/install the application. I had a look into the global assembly cache and the assembly is installed in the correct version. Additionally the is no reference to this assembly in my application... .
Where is my fault? How can I fix the problem.
Thanks in Advance
Alex
