I am new to Vs2010 and Infragistics 13.1. My company is using Infragistics 10.3 and planning to upgrade to 13.1. Now i was assigned to do a POC for showing Pivot grid in our environment.
I have referred some of online documents from here. But i am not able to achieve the simple Pivot Grid connecting Oracle Database.
It would be better if anyone can give me a sample project
Hello Narasimhan,
Thank you for your feedback. Looking forward to hearing from you.
Sincerely,
Krasimir
Developer Support Engineer
www.infragistics.com/support
Hi Krasimir,
We are trying to set up the Oracle 11 version for making the OracleOLAPservice. Hopefully, we will make by a week.
I will get in touch with this thread once after setting up.
Narasimhan.
Hi Narasimhan,If you have Provider Services (Oracle Essbase - Analytic Provider Services) installed and configured along with Essbase, you should be able to browse to the URL:"http://nameOfOracleServer/aps/XMLA" which is the value of the ServerUri configuration parameter.For the XmlaOracleConnectionSettings.DiscoverProperties's code snippet, respectively, the value of the Provider property is Essbase while the Data Source property should be set to the name of the Oracle server.The credentials for a user and password are the ones for Analytic Provider Services.Please let me know if I could be of further help on the matter.P.S. We move your forum thread to the PivotGrid section of our WPF community site.Best Regards,Milana Zhileva
Hi Narasimhan,Thank you for your reply. I will investigate your issue further and get back to you.Regards,Milana Zhileva
