Hi
I'm trying to implement a "select all" functionality with checkboxes on the Header and record selector based on the example in the wpf sample browser. All seems well except the style for record selector removes the filter icon which removes all the filters with one click. How should i fix this?
Here's the style i'm using:
<Style TargetType="{x:Type igDP:RecordSelector}" BasedOn="{x:Null}">
<Setter Property="Template">
<Setter.Value>
<ControlTemplate TargetType="{x:Type igDP:RecordSelector}">
<CheckBox HorizontalAlignment="Center" VerticalAlignment="Center" IsChecked="{Binding Path=DataItem.IsChecked, Mode=TwoWay}" />
</ControlTemplate>
</Setter.Value>
</Setter>
</Style>
I have been looking into your post and I am not sure how exactly the checkbox on the filter record removes the filter icon. It would be great if you could attach a descriptive screenshot.
I was wondering if the checkbox is necessary for the filter record. If it is not, you can hide it like :
<CheckBox HorizontalAlignment="Center" VerticalAlignment="Center" />
<Style.Triggers>
<DataTrigger Binding="{Binding RelativeSource={RelativeSource Self}, Path=IsFilterRecord}" Value="True">
<Setter Property="Visibility" Value="Hidden" />
</DataTrigger>
</Style.Triggers>
