Hi Infragistics,
I'm trying to highlight some data in a bar or column series. I want a few of the columns to be highlighted, not just one category. In an ideal world, most of the columns would be semi-opaque, and the highlighted columns would not.
I'm populating my data from a view model, so the normal WPF way is to have an 'IsHighlighted' property in each data point view model, and use a data trigger in a style in Xaml. All very neat.
Not so, apparently. I've seen some horrendous workarounds on the forum for the people who come across this problem. The most likely solution was a few hundred lines of code.
Note, some have suggested I use a series for each column and set the opacity there. That doesn't work in my scenario because I'm also creating clustered and stacked charts.
Help!
Pete
all ok thanks.
Hi ,
Please let me know if you need further assistance regarding this issue.
You can suggest new product ideas for future versions (or vote for existing ones) at <http://ideas.infragistics.com>.
There are many benefits to submitting a product idea:
- Direct communication with our product management team regarding your product idea.
- Notifications whenever new information regarding your idea becomes available.
- Ability to vote on your favorite product ideas to let us know which ones are the most important to you. You will have ten votes for this and can change which ideas you are voting for at any time.
- Allow you to shape the future of our products by requesting new controls and products altogether.
- You and other developers can discuss existing product ideas with members of our Product Management team.
Steps to create your idea:
1. Log into the Infragistics Product Idea site at http://ideas.infragistics.com (creating a new login if needed).
2. Navigate to the product / platform channel of your choice (e.g. WPF, Windows Forms, ASP.NET, HTML5 / Ignite UI, iOS / NucliOS, etc.)
3. Add your product idea and be sure to be specific and provide as much detail as possible. Explain the context in which a feature would be used, why it is needed, why it can’t be accomplished today, and who would benefit from it. You can even add screenshots to build a stronger case. Remember that for your suggestion to be successful, you need other members of the community to vote for it. Be convincing!
The Product Idea site puts you in the driver’s seat and allows you to track the progress of your ideas at any time, see how many votes it got, read comments from other developers in the community, and see if someone from the product team has additional questions for you.
Thank you for contacting Infragistics.
Sincerely,
Matt
Developer Support Engineer
Matt,
thanks for your continued support.
We've found a temporary solution by altering the code in the ColumnSeries to popupate the data context with our data item, and then just using a binding in the implicit Rectangle style. I think you're right that we should submit a feature request, as we don't benefit from your unit tests or quality assurance if we change the code ourselves.
At least we can continue with our implementation.
HI,
We should submit a feature request for this issue.
I have another solution that will work as long as the columns of the chart are not scrolled in an out of view.
I making use of the Rectangle Loaded event. As each chart is loaded, I put an index number in the tag property.
Here is my sample.
MattDeveloper Support Engineer
