from time to time we get an unhandled exception from the DockManager telling that "A deffered show is already in progress".
What is the reason for this exception and how can it be fixed?
Here is the call stack:
[Window Title]
An unhandled exception has occured.
[Content]
System.InvalidOperationException: A deferred show is already in progress.
at Infragistics.Windows.Controls.ToolWindow.ShowImpl(FrameworkElement owner)
at Infragistics.Windows.Controls.ToolWindow.ShowAsync(FrameworkElement owner, Boolean activate, Boolean preferPopup)
at Infragistics.Windows.DockManager.DockManagerUtilities.ShowToolWindow(ToolWindow window, FrameworkElement owner, Boolean activate)
at Infragistics.Windows.DockManager.PaneToolWindow.ShowHelper()
at Infragistics.Windows.DockManager.PaneToolWindow.set_IsWindowLoaded(Boolean value)
at Infragistics.Windows.DockManager.XamDockManager.SetIsWindowLoaded(PaneToolWindow window, Boolean loaded)
at Infragistics.Windows.DockManager.XamDockManager.SetIsWindowLoaded(Boolean loaded)
at Infragistics.Windows.DockManager.XamDockManager.VerifyFloatingWindowVisibility()
at Infragistics.Windows.DockManager.XamDockManager.OnDockManagerLoaded(Object sender, RoutedEventArgs e)
at System.Windows.RoutedEventHandlerInfo.InvokeHandler(Object target, RoutedEventArgs routedEventArgs)
at System.Windows.EventRoute.InvokeHandlersImpl(Object source, RoutedEventArgs args, Boolean reRaised)
at System.Windows.UIElement.RaiseEventImpl(DependencyObject sender, RoutedEventArgs args)
at System.Windows.UIElement.RaiseEvent(RoutedEventArgs e)
at System.Windows.BroadcastEventHelper.BroadcastEvent(DependencyObject root, RoutedEvent routedEvent)
at System.Windows.BroadcastEventHelper.BroadcastLoadedEvent(Object root)
at MS.Internal.LoadedOrUnloadedOperation.DoWork()
at System.Windows.Media.MediaContext.FireLoadedPendingCallbacks()
at System.Windows.Media.MediaContext.FireInvokeOnRenderCallbacks()
at System.Windows.Media.MediaContext.RenderMessageHandlerCore(Object resizedCompositionTarget)
at System.Windows.Media.MediaContext.RenderMessageHandler(Object resizedCompositionTarget)
at System.Windows.Media.MediaContext.Resize(ICompositionTarget resizedCompositionTarget)
at System.Windows.Interop.HwndTarget.OnResize()
at System.Windows.Interop.HwndTarget.HandleMessage(WindowMessage msg, IntPtr wparam, IntPtr lparam)
at System.Windows.Interop.HwndSource.HwndTargetFilterMessage(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
at MS.Win32.HwndWrapper.WndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
at MS.Win32.HwndSubclass.DispatcherCallbackOperation(Object o)
at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs)
at MS.Internal.Threading.ExceptionFilterHelper.TryCatchWhen(Object source, Delegate method, Object args, Int32 numArgs, Delegate catchHandler)
Hello Matthew,
I have tested your scenario and I wasn't able to reproduce your issue. I connected to a RDP, start the application, close the connection and then open the connection again. I attached the sample I used for testing. If the sample doesn’t satisfies all your needs feel free to modify it, so it reproduces your behavior and send it back to me for further investigation. Also if the steps you follow are different could you please write them, so we could reproduce this on our side?
You should have enough evidence from my description and stack trace and issue reported above to reproduce the issue. Please use your own sample code for XamDockManager and a RDP session to reproduce the exception.
FYI, there is an open support case on these issues (CAS-132383-Y6R0Z1)
Could please try to isolate a sample project and send it to us, so we could be able to investigate this further for you? Also it will be very helpful if you tell us the steps we need to follow in order to reproduce this.
Hello... any response to my reproduction case below?
Thanks.
