I am using InfragisticsWPF4.Controls.Charts.XamDataChart.v12.2 version 12.2.20122.1000.
When i am implementing the pir chart, the color repeatation occurs after 5 or more legends are there.
Can you let me know how can this bs handled or this is a bug in infragistics pie chart.
igCharts:ItemLegend Grid.Row="1" Grid.Column="1" Name="lgndComapany" Cursor="Hand" VerticalAlignment="Center" Margin="50,0,0,0"
Width="Auto" HorizontalAlignment="Right" LegendItemMouseLeftButtonUp="LgndComapany_OnLegendItemMouseLeftButtonUp">
</igCharts:ItemLegend>
<igCharts:XamPieChart Grid.Row="1" Grid.Column="0" ItemsSource="{Binding OwnershipCollection}"
LabelMemberPath="CompanyName" OthersCategoryThreshold="0" LabelsPosition="BestFit"
ToolTip="{}{CompanyName}" Legend="{Binding ElementName=lgndComapany}"
Name="pieChrtOwnership" ValueMemberPath="InterestPercent" Height="350" AllowSliceExplosion="True">
<igCharts:XamPieChart.LabelTemplate>
<DataTemplate>
<TextBlock Text="{Binding PercentValue, StringFormat=n}" />
</DataTemplate>
</igCharts:XamPieChart.LabelTemplate>
</igCharts:XamPieChart>
Rajiv
Hello Rajiv,
I am just checking if you got this worked out or you still require any assistance or clarification on the matter.
The XamPieChart's Brushes property is a BrusheColelction, which is ObservableCollection<Brush> type, so the objects you add can be SolidColorBrushes for which you can define the Color by setting the R ,G, B and A Properties. Please let me know if this helps you or you have further questions on this matter.
Can i implement RGB color (dark only) in xampie chart in wpf.
The XamPieChart's Brushes collection can be set run time. Once it is set the XamPieChart will be updated with the new colors.
