I create a huge sheet with 1048576 rows.
If 1. Create a Workbook; 2. Add a Worksheet to Workbook; 3. Fill Worksheet with 1048576 rows; 4. Set Workbook to XamSpreadsheet.Workbook property.It works(CreateBackground_OnClick, LoadButton_OnClick). If 1. Get Workbook from XamSpreadsheet.Workbook property. 2. Get ActiveWorksheet; 3. Fill ActiveWorksheet with 1048576 rows.It throws OutOfMemoryException(CreateDirectly_OnClick).Redo/Undo and other capabilities need memory? If so, how can avoid this?For example: var workbook = spread.Workbook; workbook.SetCurrentFormat(WorkbookFormat.Excel2007); spread.BeginUpdate(); // mark update beginning FillWorksheet(spread.ActiveWorksheet, 1048576); spread.EndUpdate(); // mark update endBetween BeginUpdate() and EndUpdate(), XamSpreadsheet seems as lost memory.Thus create some rows, just do once, also undo once.
Thank you!
What's the difference?
===============================================================================<Window xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation" xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml" xmlns:ig="http://schemas.infragistics.com/xaml" x:Class="SpreadTest.MainWindow" Title="MainWindow" Height="350" Width="525"> <Grid> <Grid.RowDefinitions> <RowDefinition Height="Auto"/> <RowDefinition Height="*"/> </Grid.RowDefinitions>
<StackPanel Orientation="Horizontal"> <Button Margin="5" Content="Create Directly" Click="CreateDirectly_OnClick"/> <Button Margin="5" Content="Create Background" Click="CreateBackground_OnClick"/> <Button Margin="5" Content="Create File" Click="CreateFile_OnClick"/> <Button Margin="5" Content="Load File" Click="LoadButton_OnClick"/> </StackPanel> <ig:XamSpreadsheet x:Name="spread" Grid.Row="1"/> </Grid></Window>
using System;using System.Diagnostics;using System.IO;using System.Windows;using Infragistics.Documents.Excel;
namespace SpreadTest{ /// <summary> /// Interaction logic for MainWindow.xaml /// </summary> public partial class MainWindow : Window { public MainWindow() { InitializeComponent(); }
private void CreateDirectly_OnClick(object sender, RoutedEventArgs e) { var workbook = spread.Workbook; workbook.SetCurrentFormat(WorkbookFormat.Excel2007); FillWorksheet(spread.ActiveWorksheet, 1048576); }
private void CreateBackground_OnClick(object sender, RoutedEventArgs e) { var workbook = new Workbook(); workbook.SetCurrentFormat(WorkbookFormat.Excel2007); var sheet = workbook.Worksheets.Add(string.Format("Data Sheet")); FillWorksheet(sheet, 1048576); spread.Workbook = workbook; }
private void LoadButton_OnClick(object sender, RoutedEventArgs e) { var workbook = Workbook.Load(@"F:\test.xlsx"); if (workbook != null) { spread.Workbook = workbook; } }
private void CreateFile_OnClick(object sender, RoutedEventArgs e) { // Create a Workbook object var workbook = new Workbook(); workbook.SetCurrentFormat(WorkbookFormat.Excel2007);
// Create a Worksheet object that contains the actual data in the workbook var sheet = workbook.Worksheets.Add(string.Format("Data Sheet")); FillWorksheet(sheet, 1048576);
using (Stream stream = File.Open(@"F:\test.xlsx", FileMode.OpenOrCreate)) { Console.WriteLine("Begin writing file ...");
workbook.Save(stream);
Console.WriteLine("Complete, Pressure any key to continue ..."); } }
private void FillWorksheet(Worksheet sheet, int numberOfRows) { var sw = new Stopwatch(); sw.Start();
for (int index = 0; index < numberOfRows; index++) { var row = sheet.Rows[index]; row.Cells[0].Value = string.Format("{0:X8}", index);
var timeSpan = sw.Elapsed; row.Cells[1].Value = timeSpan.Hours * 10000000 + timeSpan.Minutes * 100000 + timeSpan.Seconds * 1000 + timeSpan.Milliseconds; row.Cells[2].Value = timeSpan.TotalMilliseconds; row.Cells[3].Value = timeSpan.Ticks;
row.Cells[4].Value = "F"; row.Cells[5].Value = "400"; row.Cells[6].Value = "50"; row.Cells[7].Value = "50, 30, 567"; row.Cells[8].Value = "2015-12-12"; row.Cells[9].Value = "Feature Co. Ltd."; row.Cells[10].Value = "Star War Plan"; row.Cells[11].Value = "+1-212-123-1234"; row.Cells[12].Value = "0123456789-1234567890"; row.Cells[13].Value = "abcdefgabcdefg hijklnm"; row.Cells[14].Value = "OPQRST UVWXYZ"; row.Cells[15].Value = "Description: For free use"; row.Cells[16].Value = "Indoors use only"; row.Cells[17].Value = "Maybe you know world trip is a nice thing, o ha ..."; row.Cells[18].Value = "E-Mail: your.name@outlook.com"; row.Cells[19].Value = "Say something, I feel lonely, thank you.";
if (index % 1000 == 0) { Console.WriteLine(index); }
sw.Stop(); }
Hi Linden,
Do you have any questions on what Andrew said about grouping transactions?
You can group your multiple changes (the 5 or 500) into a single undo unit by wrapping the changes within a transaction - e.g. using the ExecuteInTransaction method of the UndoManager.
I don't want 1M rows change to be undoable. I just want the capability: a group operation as one unit undo.
May be 5 rows, or may be 500 row.
Thank you.
Do you have any questions regarding Andrew's explanation?
