I am using the following blog post to bind to the XamDockManager.
http://ko.infragistics.com/community/blogs/blagunas/archive/2013/09/24/xamdockmanager-data-binding-contentpanes-with-mvvm.aspx
The context is that the user creates a project from a certain file, they add things to their project, and then they choose to save the project. The project is then saved to disk and reloaded into the ViewModel. This change in ViewModel values is throwing the OnItemsSourcePropertyChanged method off. So I save the project, then set the property that binds to the ItemsSource property to null, then I need to reload the project. The issue comes when I set the ItemsSource to null (I am binding to an ObservableCollection and have tried newing up an ObservableCollection or clearing it, but it does not work either). In the OnItemsSourcePropertyChanged method on the call to AssociatedObject.Items.Clear(), I get the null pointer exception. There are items going into the call, but somewhere in the cleanup something gets messed up. Somewhere deep in the infragistics code that gets called, there is an issue.
Here is the stacktrace:
System.NullReferenceException occurred HResult=-2147467261 Message=Object reference not set to an instance of an object. Source=PresentationFramework StackTrace: at System.Windows.Controls.ItemContainerGenerator.ContainerFromIndex(Int32 index) at Infragistics.Windows.DockManager.TabGroupPane.VerifySelectedItem(Object param) at Infragistics.Windows.DockManager.TabGroupPane.VerifySelectedItem() at Infragistics.Windows.DockManager.TabGroupPane.OnGeneratorStatusChanged(Object sender, EventArgs e) at System.EventHandler.Invoke(Object sender, EventArgs e) at System.Windows.Controls.ItemContainerGenerator.SetStatus(GeneratorStatus value) at System.Windows.Controls.ItemContainerGenerator.Generator.System.IDisposable.Dispose() at Infragistics.Windows.DockManager.DocumentTabPanel.MeasureOverride(Size availableSize) at System.Windows.FrameworkElement.MeasureCore(Size availableSize) at System.Windows.UIElement.Measure(Size availableSize) at System.Windows.ContextLayoutManager.UpdateLayout() at Infragistics.Windows.DataPresenter.DataPresenterBase.OnThemeChanged(DependencyObject target, DependencyPropertyChangedEventArgs e) at System.Windows.PropertyChangedCallback.Invoke(DependencyObject d, DependencyPropertyChangedEventArgs e) at System.Windows.DependencyObject.OnPropertyChanged(DependencyPropertyChangedEventArgs e) at System.Windows.FrameworkElement.OnPropertyChanged(DependencyPropertyChangedEventArgs e) at Infragistics.Windows.DataPresenter.DataPresenterBase.OnPropertyChanged(DependencyPropertyChangedEventArgs e) at Infragistics.Windows.DataPresenter.XamDataGrid.OnPropertyChanged(DependencyPropertyChangedEventArgs e) at System.Windows.DependencyObject.NotifyPropertyChange(DependencyPropertyChangedEventArgs args) at System.Windows.DependencyObject.UpdateEffectiveValue(EntryIndex entryIndex, DependencyProperty dp, PropertyMetadata metadata, EffectiveValueEntry oldEntry, EffectiveValueEntry& newEntry, Boolean coerceWithDeferredReference, Boolean coerceWithCurrentValue, OperationType operationType) at System.Windows.DependencyObject.InvalidateProperty(DependencyProperty dp, Boolean preserveCurrentValue) at System.Windows.StyleHelper.InvalidatePropertiesOnTemplateNode(DependencyObject container, FrameworkObject child, Int32 childIndex, FrugalStructList`1& childRecordFromChildIndex, Boolean isDetach, FrameworkElementFactory templateRoot) at System.Windows.StyleHelper.ClearTemplateChain(HybridDictionary[] instanceData, FrameworkElement feContainer, FrameworkContentElement fceContainer, List`1 templateChain, FrameworkTemplate oldFrameworkTemplate) at System.Windows.StyleHelper.ClearGeneratedSubTree(HybridDictionary[] instanceData, FrameworkElement feContainer, FrameworkContentElement fceContainer, FrameworkTemplate oldFrameworkTemplate) at System.Windows.StyleHelper.DoTemplateInvalidations(FrameworkElement feContainer, FrameworkTemplate oldFrameworkTemplate) at System.Windows.StyleHelper.UpdateTemplateCache(FrameworkElement fe, FrameworkTemplate oldTemplate, FrameworkTemplate newTemplate, DependencyProperty templateProperty) at System.Windows.Controls.ContentPresenter.OnTemplateChanged(DependencyObject d, DependencyPropertyChangedEventArgs e) at System.Windows.DependencyObject.OnPropertyChanged(DependencyPropertyChangedEventArgs e) at System.Windows.FrameworkElement.OnPropertyChanged(DependencyPropertyChangedEventArgs e) at System.Windows.DependencyObject.NotifyPropertyChange(DependencyPropertyChangedEventArgs args) at System.Windows.DependencyObject.UpdateEffectiveValue(EntryIndex entryIndex, DependencyProperty dp, PropertyMetadata metadata, EffectiveValueEntry oldEntry, EffectiveValueEntry& newEntry, Boolean coerceWithDeferredReference, Boolean coerceWithCurrentValue, OperationType operationType) at System.Windows.DependencyObject.SetValueCommon(DependencyProperty dp, Object value, PropertyMetadata metadata, Boolean coerceWithDeferredReference, Boolean coerceWithCurrentValue, OperationType operationType, Boolean isInternal) at System.Windows.DependencyObject.SetValue(DependencyProperty dp, Object value) at System.Windows.Controls.ContentPresenter.OnContentTemplateChanged(DependencyObject d, DependencyPropertyChangedEventArgs e) at System.Windows.DependencyObject.OnPropertyChanged(DependencyPropertyChangedEventArgs e) at System.Windows.FrameworkElement.OnPropertyChanged(DependencyPropertyChangedEventArgs e) at System.Windows.DependencyObject.NotifyPropertyChange(DependencyPropertyChangedEventArgs args) at System.Windows.DependencyObject.UpdateEffectiveValue(EntryIndex entryIndex, DependencyProperty dp, PropertyMetadata metadata, EffectiveValueEntry oldEntry, EffectiveValueEntry& newEntry, Boolean coerceWithDeferredReference, Boolean coerceWithCurrentValue, OperationType operationType) at System.Windows.DependencyObject.InvalidateProperty(DependencyProperty dp, Boolean preserveCurrentValue) at System.Windows.StyleHelper.InvalidatePropertiesOnTemplateNode(DependencyObject container, FrameworkObject child, Int32 childIndex, FrugalStructList`1& childRecordFromChildIndex, Boolean isDetach, FrameworkElementFactory templateRoot) at System.Windows.StyleHelper.ClearTemplateChain(HybridDictionary[] instanceData, FrameworkElement feContainer, FrameworkContentElement fceContainer, List`1 templateChain, FrameworkTemplate oldFrameworkTemplate) at System.Windows.StyleHelper.ClearGeneratedSubTree(HybridDictionary[] instanceData, FrameworkElement feContainer, FrameworkContentElement fceContainer, FrameworkTemplate oldFrameworkTemplate) at System.Windows.StyleHelper.DoTemplateInvalidations(FrameworkElement feContainer, FrameworkTemplate oldFrameworkTemplate) at System.Windows.StyleHelper.UpdateTemplateCache(FrameworkElement fe, FrameworkTemplate oldTemplate, FrameworkTemplate newTemplate, DependencyProperty templateProperty) at System.Windows.Controls.Control.OnTemplateChanged(DependencyObject d, DependencyPropertyChangedEventArgs e) at System.Windows.DependencyObject.OnPropertyChanged(DependencyPropertyChangedEventArgs e) at System.Windows.FrameworkElement.OnPropertyChanged(DependencyPropertyChangedEventArgs e) at System.Windows.DependencyObject.NotifyPropertyChange(DependencyPropertyChangedEventArgs args) at System.Windows.DependencyObject.UpdateEffectiveValue(EntryIndex entryIndex, DependencyProperty dp, PropertyMetadata metadata, EffectiveValueEntry oldEntry, EffectiveValueEntry& newEntry, Boolean coerceWithDeferredReference, Boolean coerceWithCurrentValue, OperationType operationType) at System.Windows.DependencyObject.InvalidateProperty(DependencyProperty dp, Boolean preserveCurrentValue) at System.Windows.StyleHelper.InvalidateContainerDependents(DependencyObject container, FrugalStructList`1& exclusionContainerDependents, FrugalStructList`1& oldContainerDependents, FrugalStructList`1& newContainerDependents) at System.Windows.StyleHelper.DoStyleInvalidations(FrameworkElement fe, FrameworkContentElement fce, Style oldStyle, Style newStyle) at System.Windows.StyleHelper.UpdateStyleCache(FrameworkElement fe, FrameworkContentElement fce, Style oldStyle, Style newStyle, Style& styleCache) at System.Windows.FrameworkElement.OnStyleChanged(DependencyObject d, DependencyPropertyChangedEventArgs e) at System.Windows.DependencyObject.OnPropertyChanged(DependencyPropertyChangedEventArgs e) at System.Windows.FrameworkElement.OnPropertyChanged(DependencyPropertyChangedEventArgs e) at System.Windows.DependencyObject.NotifyPropertyChange(DependencyPropertyChangedEventArgs args) at System.Windows.DependencyObject.UpdateEffectiveValue(EntryIndex entryIndex, DependencyProperty dp, PropertyMetadata metadata, EffectiveValueEntry oldEntry, EffectiveValueEntry& newEntry, Boolean coerceWithDeferredReference, Boolean coerceWithCurrentValue, OperationType operationType) at System.Windows.DependencyObject.InvalidateProperty(DependencyProperty dp, Boolean preserveCurrentValue) at System.Windows.FrameworkElement.UpdateStyleProperty() at System.Windows.TreeWalkHelper.InvalidateOnTreeChange(FrameworkElement fe, FrameworkContentElement fce, DependencyObject parent, Boolean isAddOperation) at System.Windows.FrameworkElement.OnVisualParentChanged(DependencyObject oldParent) at System.Windows.Media.Visual.FireOnVisualParentChanged(DependencyObject oldParent) at System.Windows.Media.Visual.RemoveVisualChild(Visual child) at System.Windows.FrameworkElement.set_TemplateChild(UIElement value) at System.Windows.StyleHelper.DetachGeneratedSubTree(FrameworkElement feContainer, FrameworkContentElement fceContainer) at System.Windows.StyleHelper.DoTemplateInvalidations(FrameworkElement feContainer, FrameworkTemplate oldFrameworkTemplate) at System.Windows.StyleHelper.UpdateTemplateCache(FrameworkElement fe, FrameworkTemplate oldTemplate, FrameworkTemplate newTemplate, DependencyProperty templateProperty) at System.Windows.Controls.ContentPresenter.OnTemplateChanged(DependencyObject d, DependencyPropertyChangedEventArgs e) at System.Windows.DependencyObject.OnPropertyChanged(DependencyPropertyChangedEventArgs e) at System.Windows.FrameworkElement.OnPropertyChanged(DependencyPropertyChangedEventArgs e) at System.Windows.DependencyObject.NotifyPropertyChange(DependencyPropertyChangedEventArgs args) at System.Windows.DependencyObject.UpdateEffectiveValue(EntryIndex entryIndex, DependencyProperty dp, PropertyMetadata metadata, EffectiveValueEntry oldEntry, EffectiveValueEntry& newEntry, Boolean coerceWithDeferredReference, Boolean coerceWithCurrentValue, OperationType operationType) at System.Windows.DependencyObject.SetValueCommon(DependencyProperty dp, Object value, PropertyMetadata metadata, Boolean coerceWithDeferredReference, Boolean coerceWithCurrentValue, OperationType operationType, Boolean isInternal) at System.Windows.DependencyObject.SetValue(DependencyProperty dp, Object value) at System.Windows.Controls.ContentPresenter.OnContentChanged(DependencyObject d, DependencyPropertyChangedEventArgs e) at System.Windows.DependencyObject.OnPropertyChanged(DependencyPropertyChangedEventArgs e) at System.Windows.FrameworkElement.OnPropertyChanged(DependencyPropertyChangedEventArgs e) at System.Windows.DependencyObject.NotifyPropertyChange(DependencyPropertyChangedEventArgs args) at System.Windows.DependencyObject.UpdateEffectiveValue(EntryIndex entryIndex, DependencyProperty dp, PropertyMetadata metadata, EffectiveValueEntry oldEntry, EffectiveValueEntry& newEntry, Boolean coerceWithDeferredReference, Boolean coerceWithCurrentValue, OperationType operationType) at System.Windows.DependencyObject.InvalidateProperty(DependencyProperty dp, Boolean preserveCurrentValue) at System.Windows.StyleHelper.InvalidateDependents(Style ownerStyle, FrameworkTemplate frameworkTemplate, DependencyObject container, DependencyProperty dp, FrugalStructList`1& dependents, Boolean invalidateOnlyContainer) at System.Windows.StyleHelper.OnTriggerSourcePropertyInvalidated(Style ownerStyle, FrameworkTemplate frameworkTemplate, DependencyObject container, DependencyProperty dp, DependencyPropertyChangedEventArgs changedArgs, Boolean invalidateOnlyContainer, FrugalStructList`1& triggerSourceRecordFromChildIndex, FrugalMap& propertyTriggersWithActions, Int32 sourceChildIndex) at System.Windows.FrameworkElement.OnPropertyChanged(DependencyPropertyChangedEventArgs e) at System.Windows.DependencyObject.NotifyPropertyChange(DependencyPropertyChangedEventArgs args) at System.Windows.DependencyObject.UpdateEffectiveValue(EntryIndex entryIndex, DependencyProperty dp, PropertyMetadata metadata, EffectiveValueEntry oldEntry, EffectiveValueEntry& newEntry, Boolean coerceWithDeferredReference, Boolean coerceWithCurrentValue, OperationType operationType) at System.Windows.DependencyObject.SetValueCommon(DependencyProperty dp, Object value, PropertyMetadata metadata, Boolean coerceWithDeferredReference, Boolean coerceWithCurrentValue, OperationType operationType, Boolean isInternal) at System.Windows.DependencyObject.SetValue(DependencyPropertyKey key, Object value) at Infragistics.Windows.DockManager.PaneTabItem.OnContentChanged(Object oldContent, Object newContent) at System.Windows.Controls.ContentControl.OnContentChanged(DependencyObject d, DependencyPropertyChangedEventArgs e) at System.Windows.DependencyObject.OnPropertyChanged(DependencyPropertyChangedEventArgs e) at System.Windows.FrameworkElement.OnPropertyChanged(DependencyPropertyChangedEventArgs e) at Infragistics.Windows.Controls.TabItemEx.OnPropertyChanged(DependencyPropertyChangedEventArgs e) at System.Windows.DependencyObject.NotifyPropertyChange(DependencyPropertyChangedEventArgs args) at System.Windows.DependencyObject.UpdateEffectiveValue(EntryIndex entryIndex, DependencyProperty dp, PropertyMetadata metadata, EffectiveValueEntry oldEntry, EffectiveValueEntry& newEntry, Boolean coerceWithDeferredReference, Boolean coerceWithCurrentValue, OperationType operationType) at System.Windows.DependencyObject.SetValueCommon(DependencyProperty dp, Object value, PropertyMetadata metadata, Boolean coerceWithDeferredReference, Boolean coerceWithCurrentValue, OperationType operationType, Boolean isInternal) at System.Windows.DependencyObject.SetValue(DependencyProperty dp, Object value) at System.Windows.Controls.HeaderedContentControl.ClearHeaderedContentControl(Object item) at System.Windows.Controls.Primitives.Selector.ClearContainerForItemOverride(DependencyObject element, Object item) at Infragistics.Windows.DockManager.TabGroupPane.ClearContainerForItemOverride(DependencyObject element, Object item) at System.Windows.Controls.ItemsControl.MS.Internal.Controls.IGeneratorHost.ClearContainerForItem(DependencyObject container, Object item) at System.Windows.Controls.ItemContainerGenerator.UnlinkContainerFromItem(DependencyObject container, Object item, IGeneratorHost host) at System.Windows.Controls.ItemContainerGenerator.RemoveAllInternal(Boolean saveRecycleQueue) at System.Windows.Controls.ItemContainerGenerator.OnCollectionChanged(Object sender, NotifyCollectionChangedEventArgs args) at System.Windows.WeakEventManager.ListenerList`1.DeliverEvent(Object sender, EventArgs e, Type managerType) at System.Windows.WeakEventManager.DeliverEventToList(Object sender, EventArgs args, ListenerList list) at System.Windows.WeakEventManager.DeliverEvent(Object sender, EventArgs args) at System.Collections.Specialized.NotifyCollectionChangedEventHandler.Invoke(Object sender, NotifyCollectionChangedEventArgs e) at System.Windows.Data.CollectionView.OnCollectionChanged(NotifyCollectionChangedEventArgs args) at System.Windows.WeakEventManager.ListenerList`1.DeliverEvent(Object sender, EventArgs e, Type managerType) at System.Windows.WeakEventManager.DeliverEventToList(Object sender, EventArgs args, ListenerList list) at System.Windows.WeakEventManager.DeliverEvent(Object sender, EventArgs args) at System.Windows.Data.CollectionView.OnCollectionChanged(NotifyCollectionChangedEventArgs args) at MS.Internal.Controls.InnerItemCollectionView.RefreshOverride() at System.Windows.Data.CollectionView.RefreshInternal() at MS.Internal.Controls.InnerItemCollectionView.Clear() at System.Windows.Controls.ItemCollection.Clear() at SSI.Windows.Simulation.Conjoint.TabGroupPaneItemsSourceBehavior.OnItemsSourcePropertyChanged(IList oldValue, IList newValue) in c:\path\TabGroupPaneItemsSourceBehavior.cs:line 59 InnerException:
Please help! Thanks!
Jon
Hi Jon,
Thank you for your post. I have been looking into your issue and I was wondering whether you could attach a sample application that demonstrates the reported issue. I would like to investigate it because the provided functionality from the above blog is custom.
I am unable to duplicate the issue with a simple project. Do you mind taking a look at my real project privately?
I have changed my layout to have the UserControl and just noticed I lost some functionality.
Inside my UserControl, I have a Grid -> Grid + GridSplitter + Grid.
In the outer grid's row definitions, the first Grid in the Grid is set to auto with a minheight of 50, the gridsplitter is set to auto, and the last grid row is set to * with minheight 50.
For some reason, the gridsplitter is allowed to go past the bottom of the UserControl container. I understand that I could wrap a scrollviewer around the content and it would let me go down and see the gridsplitter again, but the original functionality I had was that the height of the tabgrouppane content was just filling the space available and not adding the scrollbar.
How does putting content into a usercontrol cause this issue? I have tried setting the verticalalignment and verticalcontentalignment to stretch, but the issue still occurs.
Any ideas? Thanks!
I'm not following how the use of a UserControl would impact this. If you have a RowDefinition whose Height is Auto then it will measure the element in that position within an infinite height so it would go out of view if the element in that position returns a height greater than the available height. That would happen even if you put that outer grid as the Content of a ContentPresenter (which is basically what is happening when it's directly within the DataTemplate). Do you have a sample that shows this problem in the UserControl but the same structure behaving differently when its in the DataTemplate so I could see what is happening?
Okay. I was mistaken. It was working when I had this as my structure:
<igWindows:XamTabControl.ContentTemplate> <DataTemplate> <Grid> <Grid.RowDefinitions> <RowDefinition Height="*" MinHeight="44"/> <RowDefinition Height="Auto"/> <RowDefinition Height="*" MinHeight="44"/> </Grid.RowDefinitions>
Then I switched to a XamDockManager like this:
<dockManager:XamDockManager x:Name="_dock" >
<dockManager:DocumentContentHost>
<dockManager:SplitPane> <dockManager:TabGroupPane x:Name="_dynamicTab"> <i:Interaction.Behaviors> <local:TabGroupPaneItemsSourceBehavior ItemsSource="{Binding Scenarios}" HeaderMemberPath="Label" > <local:TabGroupPaneItemsSourceBehavior.ItemTemplate> <DataTemplate> <local:MainTabContentControl /> </DataTemplate> </local:TabGroupPaneItemsSourceBehavior.ItemTemplate> </local:TabGroupPaneItemsSourceBehavior> </i:Interaction.Behaviors> </dockManager:TabGroupPane> </dockManager:SplitPane> </dockManager:DocumentContentHost> </dockManager:XamDockManager>
Then in the MainTabContentControl is the same structure as at the top:
I'm still trying to figure out what is different. In a small sample, I cannot reproduce it working under the XamTabControl example, but it does work in my real project. Do you know if there is anything special about XamTabControl content that is different than the DocumentContentHost? I will keep investigating on my real project.
Thanks!
I see the problem. Sorry. The first RowDefinition height in the UserControl is set to Auto and not *, so it just takes up as much space as it can.
Thanks. I will look for another solution.
Just in case others need to do the same thing I did, I ended up following the answer on this page. https://social.msdn.microsoft.com/Forums/vstudio/en-US/f10045d5-3c47-4401-93d4-8ef8b82fa9e5/gridsplitter-drags-out-of-the-window?forum=wpf
