How can we create a legend in Xamdatachart in which user should be able to select the LegendItem.
Based on the legend item selected I need to populate the other data. Can someone please help, its urgent
Hello Rishi,
I am just checking if you got this worked out or you still require any assistance or clarification on the matter.
It has been a while since you have made your post, in case you still need support I will be glad to assist you further. I suppose the other community members can benefit from this answer as well. I have been looking into your post and I can suggest you see the sample in the Samples Browser under xamDataChart / Display / Multiple Series section, where you can see how to check/uncheck legend items. You can use similar approach in order to populate your data, based on the checked item.
awesome support...no answer till now :)
