Xamcomboeditor not showing the value when i click the xamcomboeditor . After clicking the xamcomboeditor the dorpdown is empty . What is the reason and how can i set the dropdown not to empty .
Thank You
Jeevan Chakravarthy
Hello Jeevan,
I am just checking your progress on the issue that you are having.
If you require any further assistance please do not hesitate to ask
Thank you for your post.
I have been looking into it. I created short sample application based on your scenario and I could not managed to reproduce the behavior that you have described. If you are not able to reproduce the issue with the attached sample application, would you please modify it with the functionality, that you are using, so it reproduces the issue. This way I would be able to further investigate this for you and provide you with more detailed information on this matter.
