Infragistics Community Forum / Web / Ultimate UI for ASP.NET Web Forms / How to simulate the ALT-ENTER in excel when adding data
Maya Kirova
Maya Kirova asked on May 22, 2012 4:03 PM
I am creating an Worksheet and attempting to add data to a cell.  I want to pass what Excel uses as alt enter (chr(10)) so that my data shows up as multiple lines within a single cell.  How can this be done?
    Maya Kirova
    Maya Kirova answered on May 22, 2012 2:39 PM
    The new line that get created when you use alt+enter is actually a “/r/n” string when represented as a cell value. So to add such value you just need to add “/r/n” where you need the new line in the cell. So for example:
    cell2.Value = "Sample Text , Sample Text \r\n \r\n \r\n Some more text \r\n Custom text";
    Would generate a text in a cell with new lines. Also keep in mind that the WrapText property needs to be set to true:
    cell2.CellFormat.WrapText = ExcelDefaultableBoolean.True;
    Best Regards,
    Maya Kirova
    Developer Support Engineer
    http://ko.infragistics.com/support
      Mike Dour
      Mike Dour answered on May 22, 2012 4:03 PM
      FYI, due to a fix for issue 103739 in the latest SR of versions 11.1 and later, the cell's WrapText value will be automatically set to True when it is Default and text with newlines is set on the cell. This is mimic how MS Excel automatically turns on wrap text for a cell when Alt+Enter is used to add newlines in that cell.
Maya Kirova
14 years, 3 months ago
Feb 12, 2026 4:16 PM
