Infragistics Community Forum / Web / Ignite UI for Angular / Angular update fails from 11 to 12
Yannick Löffler
Yannick Löffler asked on Jan 19, 2022 3:58 PM
Dear infragistics team,
we tried different approaches to update from angular 11 to 12. Unfortunately, it looks like there is an internal issue with the library.
Here you can see the error during the update.
Here comes a part of the package.json
  "name": "xyz",
  "version": "0.1.0",
  "scripts": {
    "ng": "ng",
    "start": "ng serve",
    "build": "ng build"
  "private": false,
  "dependencies": {
    "@angular/animations": "12.2.15",
    "@angular/cdk": "12.2.13",
    "@angular/common": "12.2.15",
    "@angular/compiler": "12.2.15",
    "@angular/core": "12.2.15",
    "@angular/forms": "12.2.15",
    "@angular/material": "12.2.13",
    "@angular/material-moment-adapter": "12.2.13",
    "@angular/platform-browser": "12.2.15",
    "@angular/platform-browser-dynamic": "12.2.15",
    "@angular/router": "12.2.15",
    "@infragistics/igniteui-angular": "11.1.38",
    "material-icons-font": "2.1.0",
    "moment": "2.29.1",
    "rxjs": "6.6.3",
    "tslib": "^2.0.0",
    "web-animations-js": "^2.3.2",
    "zone.js": "~0.11.4"
  "devDependencies": {
    "@angular-devkit/build-angular": "12.2.15",
    "@angular-eslint/builder": "1.2.0",
    "@angular-eslint/eslint-plugin": "1.2.0",
    "@angular-eslint/eslint-plugin-template": "1.2.0",
    "@angular-eslint/schematics": "1.2.0",
    "@angular-eslint/template-parser": "1.2.0",
    "@angular/cli": "12.2.15",
    "@angular/compiler-cli": "12.2.15",
    "@types/bootstrap": "4.2.1",
    "@types/jasmine": "3.10.3",
    "@types/node": "14.14.13",
    "@typescript-eslint/eslint-plugin": "4.3.0",
    "@typescript-eslint/parser": "4.3.0",
    "eslint": "7.23.0",
    "eslint-plugin-import": "2.22.1",
    "eslint-plugin-jsdoc": "30.7.6",
    "eslint-plugin-prefer-arrow": "1.2.2",
    "jasmine-core": "4.0.0",
    "karma": "6.3.11",
    "karma-chrome-launcher": "3.1.0",
    "karma-headless-chrome-launcher": "0.0.6",
    "karma-jasmine": "4.0.1",
    "karma-jasmine-html-reporter": "1.7.0",
    "ng-packagr": "12.2.6",
    "typescript": "4.3.5"
As mentioned in the screenshot above, we tried to update the library by the command
ng update @infragistics/igniteui-angular@12 -C --force
I can ensure you, that the whole “node_modules” was deleted and the dependencies got reinstalled via npm install –force. Also, the package-lock.json matches with the package.json and is up2date.
Please have a look.
FYI: We also tried different approaches/orders for the angular 12 update. Eventually, we came up to install igx in the last step (so please don’t suggest changing the update order or trying to follow the instructions on your update page).
Y. Löffler
    Yannick Löffler
    Yannick Löffler answered on Jan 18, 2022 4:07 PM
    Looks like the screenshot didn't work…. here comes the error as a text
    Using package manager: 'npm'
    Collecting installed dependencies...
    Found 50 dependencies.
    Fetching dependency metadata from registry...
        Updating package.json with dependency @infragistics/igniteui-angular @ "12.3.9" (was "11.1.38")...
      UPDATE package.json (2139 bytes)
    √ Packages successfully installed.
      Committed migration step (573efb49c): Angular CLI update for packages - @infragistics/igniteui-angular@12.
    ** Executing migrations of package '@infragistics/igniteui-angular' **
    > Updates Ignite UI for Angular from v11.1.x to v12.0.0.
        Applying migration for Ignite UI for Angular to version 12.0.0
        Installing temporary migration dependencies via npm.
        Adding 'angularCompilerOptions.strictTemplates' to tsconfig.json for migration run.
    × Migration failed: Cannot read property 'escapedName' of undefined
      See "C:\Users\xyz\AppData\Local\Temp\ng-CuG3JR\angular-errors.log" for further details.
    Yannick Löffler
    Yannick Löffler answered on Jan 19, 2022 6:57 AM
    Hey guys,
    looks like you patched an error into the migration script of the latest 12.x.y versions.
    An update to the previous version 11.1.38 -> 12.0.11 works.
    from 12.0.11 I was able to update to the latest 12.3.9
    That works for me. I hope that helps other users, too!
      Viktor Kombov
      Viktor Kombov answered on Jan 19, 2022 3:58 PM
      Hello Yannick,
      Thank you for sharing the solution!
      I am glad that the issue has been resolved.
      Viktor Kombov
Yannick Löffler
4 years, 8 months ago
Feb 12, 2026 9:10 AM
