Infragistics Community Forum / Web / Ultimate UI for ASP.NET Web Forms / Cancel the button click event from code behind
Bernie
Bernie asked on Nov 23, 2015 8:52 AM
I am trying to figure out how to cancel the click event from code behind as I don't want my page to post back.  I can't seem to find this anywhere.  If I were to use a standard asp button I would just use the e.Cancel = True.  Thanks in advance.
    Nadia Robakova
    Nadia Robakova answered on Nov 18, 2015 11:48 AM
    Thank you for using our forum.
    You want to cancel the event you have to return false or to set e.Cancel=True.
    In which control you are trying to cancel click event?
      Bernie
      Bernie answered on Nov 18, 2015 2:06 PM
      Nadia,
      Thanks for the quick response.  I am using the WebImageButton.  I will attach some code that I am using as the code doesn't recognize the cancel method of the e object.
      Private Sub cmdSave_Click(sender As Object, e As Infragistics.WebUI.WebDataInput.ButtonEventArgs) Handles cmdSave.Click
      If UpdateRecord() Then
      MsgBox("Record is saved.", MsgBoxStyle.OkOnly, "Record Saved")
      Else
      e.cancel = True
      End If
      End Sub
        Nadia Robakova
        Nadia Robakova answered on Nov 23, 2015 8:52 AM
        It is not possible to cancel the click event from the client side.
        You can only cancel the event form the client side.
        Please let me know if I can provide any further assistance
Bernie
10 years, 8 months ago
Feb 16, 2026 9:38 PM
