Infragistics Community Forum / General / Disable Snaplines in WinForms Designer
Sandeep Shukla
Sandeep Shukla asked on Nov 25, 2015 3:05 PM
How can i disable snaplines (which is shown in the above image) in design mode( custom form with custom controls using Infagistic dlls) when we move the controls using the mouse.
    Milko Venkov
    Milko Venkov answered on Nov 25, 2015 2:51 PM
    Hello Sandeep,
    Windows Forms designer is designed to work in two layout modes: SnapLine and SnapToGrid. In order to turn of the snap lines you may switch to SnapToGrid layout mode. Please note when switch to this mode you may also consider to set Default Grid Cell Size, Show Grid and Snap to Grid properties. More about Windows Forms Designer options you may find by following the next link
    https://msdn.microsoft.com/query/dev14.query?appId=Dev14IDEF1&l=EN-US&k=k(VS.ToolsOptionsPages.WindowsFormsDesigner.General);k(TargetFrameworkMoniker-.NETFramework,Version%3Dv4.0)&rd=true
    Thank you for using Infragistics Components.
    Mike Bowshewicz
    Mike Bowshewicz answered on Nov 25, 2015 3:05 PM
    Hi Sandeep,
    This is a designer-level setting in Visual Studio and will be configured by the developer. I found a discussion on StackOverflow which describes this, and in which you participated:
    http://stackoverflow.com/questions/33756441/disable-snaplines-in-windows-froms-designer
    I will summarize some of the main points here:
    • In order to temporarily overwrite the setting, you can hold down the Alt key while moving the control.
    • If you would like to turn it off permanently, you can go to Tools > Options > Windows Forms Designer > General. From there, set the Layout Mode option to SnapToGrid. You may also want to set the Snap to Grid option to False. You will need to restart the designer for these changes to take effect.
    In the StackOverflow discussion, you asked about how this setting could be modified in code, and you elaborated that you are working on developing custom controls. You can override this setting by using the ControlDesigner class:
    https://msdn.microsoft.com/en-us/library/system.windows.forms.design.controldesigner(v=vs.110).aspx
    Please let me know whether I can assist you with any further questions related to Infragistics controls.
Sandeep Shukla
10 years, 10 months ago
Feb 23, 2026 1:17 PM
