Infragistics Community Forum / Web / Ultimate UI for ASP.NET Web Forms / Excel date format string not applied
Vaishnavi Makam
Vaishnavi Makam asked on Jul 17, 2019 5:11 AM
I have been trying to set the date format to worksheet cell but it not working. Here’s what i have –
row.Cells[columnIndex].CellFormat.FormatString = “mm/dd/yyyy h:mm AM/PM”;
row.Cells[columnIndex].CellFormat.Alignment = HorizontalCellAlignment.Right;
Due to this the filter does not work as expected. The column is considered as a text –
But the same when i do by opening the Excel from my system and then set the format, the column is correctly set as Date and the filter looks like below –
The one in the second image is the expected outcome.
Can you please help me fix this ?
    Milko Venkov
    Milko Venkov answered on Jan 22, 2019 7:03 AM
    Hello Vaishnavi,
    Following the steps you described I have created a small sample website with a single grid. Then I have exported the grid with WebExcelExporter, have set the FormatString of the date column as you did. In the exported Excel file the format of the column is correct in my sample.
    I am sending you my sample to test it on your side. Please run it and let me know what the result of this test is.
    webGridToExcel.zip
      Vaishnavi Makam
      Vaishnavi Makam answered on Jul 16, 2019 9:51 AM
      Hi Milko,
      Thank you for the sample and apologies for the very late response.
      Unfortunately i was not able to run your application. but i have managed to fix this issue.
      Original approach :
      • Add Format to the cell
      • Assign the string value to the cell
      Fix :
      • Add Format to the Cell
      • Parse the string value to the exact date format
      • Assign the datetime value to the cell.
      Not sure if this is supposed to be done so or if this is fixed in the later version.
      Thanks again for the quick response [emoticon:c4563cd7d5574777a71c318021cbbcc8]
      Thanks & Regards,
      Vaishnavi M G
        Milko Venkov
        Milko Venkov answered on Jul 16, 2019 11:36 AM
        Hi Vaishnavi,
        If you are assigning the cells' values you should convert them to dates, so what you did is correct. However, WebExcelExporter does this for you out of the box. Here is how I have exported the grid to Excel in my sample:
        string fileName = "result";
        this.WebExcelExporter1.DownloadName = fileName;
        this.WebExcelExporter1.WorkbookFormat = Infragistics.Documents.Excel.WorkbookFormat.Excel2007;
        var wb = new Workbook();
        var ws = wb.Worksheets.Add("MyGrid");
        ws.Columns[INDEX_OF_DATE_COLUMN].CellFormat.FormatString = @"mm/dd/yyyy h:mm AM/PM";
        ws.Columns[INDEX_OF_DATE_COLUMN].].CellFormat.Alignment = HorizontalCellAlignment.Right;
        this.WebExcelExporter1.Export(this.WebDataGrid1, ws);
        As a result WebExcelExporter exports the date column of my grid correctly.
        Vaishnavi Makam
        Vaishnavi Makam answered on Jul 17, 2019 5:11 AM
        Got it. But we are not using WebExcelExporter.
        Anyway thanks for clarifying that [emoticon:c4563cd7d5574777a71c318021cbbcc8]
Vaishnavi Makam
7 years, 2 months ago
Feb 19, 2026 8:07 AM
