Infragistics Community Forum / Web / Ignite UI for jQuery / iggrid fixed header not aligned with row data
Smitesh Shah
Smitesh Shah asked on Nov 25, 2025 10:20 AM
I am setting height of iggrid to set fixed header with vertical scrolling, it is fixed the header, but its not aligned with row data, please refer to this snap.
Below is the code:
$(“#tblCheckInQueList”).igGrid({
primaryKey: “templateID”,
width: ‘100%’,
height: ‘170px’,
autofitLastColumn: false,
autoGenerateColumns: false,
renderCheckboxes: true,
dataSource: data,
showHeader: true,
multiSelection: {
enabled: true
columns: [
{ headerText: “AppTypeMapID”, headerCssClass: “”, key: “appTypeMapID”, dataType: “number”, columnCssClass: “”, hidden: true },
{ headerText: “TemplateID”, headerCssClass: “”, key: “templateID”, dataType: “number”, columnCssClass: “”, hidden: true },
{ headerText: “Select”, headerCssClass: “”, key: “select”, dataType: “bool”, columnCssClass: “”, hidden: true },
{ headerText: “Questionnaire(s)”, headerCssClass: “”, key: “questTemplate”, dataType: “string”, columnCssClass: “smd-font-color” },
{ headerText: “Portal”, key: “portal”, dataType: “boolean”, hidden: true },
headerText: “Portal”, key: “portal1”, dataType: “boolean”, unbound: true, columnCssClass: “text-left”,
formula: function displayStatus(data, grid) {
var ActiveStatus = null;
if (data[“portal”] == true) {
ActiveStatus = “<label class=’custom-control custom-checkbox pmd-checkbox smd-margin-bottom-none’><input type=’checkbox’ name=’CheckInQuest_” + data[“templateID”] + “‘ class=’custom-control-input’ onclick=’activeChange(this)’ id=’chkPortalQI_” + data[“templateID”] + “‘ checked=’checked’ /><span class=’custom-control-label pmd-checkbox-ripple-effect’></span></label>”;
else {
ActiveStatus = “<label class=’custom-control custom-checkbox pmd-checkbox smd-margin-bottom-none’><input type=’checkbox’ name=’CheckInQuest_” + data[“templateID”] + “‘ class=’custom-control-input’ onclick=’activeChange(this)’ id=’chkPortalQI_” + data[“templateID”] + “‘ /><span class=’custom-control-label pmd-checkbox-ripple-effect’></span></label>”;
return ActiveStatus;
{ headerText: “Clipboard”, key: “clipboard”, dataType: “boolean”, hidden: true },
headerText: “Clipboard”, key: “clipboard1”, dataType: “boolean”, unbound: true, columnCssClass: “text-left”,
if (data[“clipboard”] == true) {
ActiveStatus = “<label class=’custom-control custom-checkbox pmd-checkbox smd-margin-bottom-none’><input type=’checkbox’ name=’CheckInQuest_” + data[“templateID”] + “‘ class=’custom-control-input’ onclick=’activeChange(this)’ id=’chkClipboardQI_” + data[“templateID”] + “‘ checked=’checked’ /><span class=’custom-control-label pmd-checkbox-ripple-effect’></span></label>”;
else {
ActiveStatus = “<label class=’custom-control custom-checkbox pmd-checkbox smd-margin-bottom-none’><input type=’checkbox’ name=’CheckInQuest_” + data[“templateID”] + “‘ class=’custom-control-input’ onclick=’activeChange(this)’ id=’chkClipboardQI_” + data[“templateID”] + “‘ /><span class=’custom-control-label pmd-checkbox-ripple-effect’></span></label>”;
{ headerText: “Both”, key: “both”, dataType: “boolean”, hidden: true },
headerText: “Both”, key: “both1”, dataType: “boolean”, unbound: true, columnCssClass: “text-left”,
if (data[“both”] == true) {
ActiveStatus = “<label class=’custom-control custom-checkbox pmd-checkbox smd-margin-bottom-none’><input type=’checkbox’ name=’CheckInQuest_” + data[“templateID”] + “‘ class=’custom-control-input’ onclick=’activeChange(this)’ id=’chkBothQI_” + data[“templateID”] + “‘ checked=’checked’ /><span class=’custom-control-label pmd-checkbox-ripple-effect’></span></label>”;
else {
ActiveStatus = “<label class=’custom-control custom-checkbox pmd-checkbox smd-margin-bottom-none’><input type=’checkbox’ name=’CheckInQuest_” + data[“templateID”] + “‘ class=’custom-control-input’ onclick=’activeChange(this)’ id=’chkBothQI_” + data[“templateID”] + “‘ /><span class=’custom-control-label pmd-checkbox-ripple-effect’></span></label>”;
// Grid Settings
features: [
enableCheckBoxes: true,
enableRowNumbering: false,
checkBoxStateChanging: function (evt, ui) {
isFiredFromCheckboxCIQ = true;
var grid = $(“#tblCheckInQueList”).data(“igGrid”);
if (ui.newState.toLowerCase() == ‘off’) {
grid.dataSource.updateRow(parseInt(ui.rowKey), { portal: false, clipboard: false, both: false }, true);
$(ui.row[0]).find(“input[id^=’chkPortalQI’]”).prop(‘checked’, false);
$(ui.row[0]).find(“input[id^=’chkClipboardQI’]”).prop(‘checked’, false);
$(ui.row[0]).find(“input[id^=’chkBothQI’]”).prop(‘checked’, false);
else {
grid.dataSource.updateRow(parseInt(ui.rowKey), { both: true }, true);
$(ui.row[0]).find(“input[id^=’chkBothQI’]”).prop(‘checked’, true);
mode: ‘row’,
persist: true,
multipleSelection: true,
activation: true,
rowSelectionChanging: function (evt, ui) {
schApptTypeIsChangesOnKeyup = true;
if (isFiredFromCheckboxCIQ) {
isFiredFromCheckboxCIQ = false;
else {
return false;
enableVerticalRendering: false,
type: “local”,
columnSettings: [
columnKey: “questTemplate”,
allowSorting: false,
columnKey: “portal1”,
columnKey: “clipboard1”,
columnKey: “both1”,
Please help to fix this issue.
    Deyan Kamburov
    Deyan Kamburov answered on Nov 9, 2021 8:37 PM
    It could be bootstrap or some custom styles related to the sample
    I tried it in the following fiddle. Please check it out. The headers are aligned as expected. Can you modify it and send it back with the misaligned headers?
Smitesh Shah
4 years, 4 months ago
Feb 12, 2026 4:04 PM
