Freeze the first two visible columns of a ultrawingrid on horizontal scroll
New DiscussionHi there,
I’m using a ultrawingrid in one of my windows project and what’s I’m trying to do is to be abled to freeze the fist two columns of the grid on a horizontal scroll. I use the following code :
e.Layout.UseFixedHeaders = true;
e.Layout.Bands[0].Columns[“hrpd_iNo”].Header.Fixed = true;
e.Layout.Bands[0].Columns[“bxpd_xDesc”].Header.Fixed = true;
This code works only if I set the ultragridband’s UseRowLayout property to false.
1) Is there a way to make this code works even if the UserRowLayout property is true?
2) I’m trying to export the same grid to EXCEL by using UltragridExcelExporter object; and my app juste freeze in the export() method…. Is it because I’m using the RowLayout in my grid also?
Thanks for your help,
Seraphin
Sign In
to post a reply
13 Created On
Dec 13, 2012 Last Post
13 years, 9 months ago
