Infragistics Community Forum / Web / Ultimate UI for ASP.NET Web Forms / Get WebGridView row from dropdownlist selectedindexchanged
Roger Tristan
Roger Tristan asked on Feb 12, 2019 6:03 AM
okay so in a typical gridview (Microsoft ASP.net one) you can put a drop down list in a template column, then in the selectedindexchanged event you can type this
    Protected Sub ddl_PackWeek_SelectedIndexChanged(ByVal sender As System.Object, ByVal e As System.EventArgs)
        Dim gd_data1 As New DataAccessLayer()
        'get dropdownlist object
        Dim Myddl As DropDownList = CType(sender, DropDownList)
        'use naming container property to get the row in which the control resides
        Dim MyRow As GridViewRow = CType(Myddl.NamingContainer, GridViewRow)
'database call
        gd_data1.updatePackWeek(MyRow.Cells(0).Text, Myddl.SelectedItem.Value)
        Me.gv_receiving.DataBind()
    End Sub
How do you do this in a web grid view?
in so many words, how do I access info from the ROW of my Drop Down List?
ASP if you need it
                                         </ItemTemplat
    Svetla Boykova
    Svetla Boykova answered on Feb 11, 2019 10:29 AM
    Hello Roger,
    You can see the following sample that demonstrates the Drop-Down Editors in WebDataGrid here.
    You can check this help help topic  as well.
    You can find the row the drop-down belongs using SelectionChanged client event as described in that forum post:
    You can find the row the drop-down belongs using SelectionChanged server event as described in that forum post:
    Svetla Boykova
      Roger Tristan
      Roger Tristan answered on Feb 11, 2019 4:01 PM
      Ok what about itemcommand ?
        Svetla Boykova
        Svetla Boykova answered on Feb 12, 2019 6:03 AM
        Hello Roger,
        You can find more information about WebDataGrid Using ItemCommand Event in the following help topic:
        Svetla Boykova
Roger Tristan
7 years, 7 months ago
Feb 23, 2026 6:58 AM
