Infragistics Community Forum / Web / Ultimate UI for ASP.NET Web Forms / How to set a gray-ish background with modal dialog?
Michael Yarbrough
Michael Yarbrough asked on Apr 6, 2009 11:06 AM
I see on some of the Infragistics examples that you are setting the background to a gray-ed out look while making a modal window pop-up. How is that done?
Thanks.
    Christopher Bishop
    Christopher Bishop answered on Mar 31, 2009 11:42 PM
    Not sure how it is done with the webdialog but to achive the same thing It is a div set to absolute position, 100%width 100%height z-index:100000 (you get the idea) using a semi-transparent png (plus for IE->dx transforms) it is pretty simple, just a css show hide deal.
      Michael Yarbrough
      Michael Yarbrough answered on Apr 1, 2009 2:38 PM
      Thanks. I tried using the ModalBackgroundCSSClass property to no avail but then used your idea instead. Here is my code to make it work along with the little Png I made for it.:
          <style type="text/css">
                         .ModalBackdrop {
                                   width: 100%;
                                   height: 100%;
                                   z-index: 100000;
                                   position: absolute;
                                   background-image: url(ModalBG.png);
                                   background-repeat: repeat;
                                   margin-top: 0px;
                                   margin-left: 0px;
              body
                        margin: 0 0 0 0;
          </style>
              function SetModal() {
                 document.getElementById("ModalBackdrop").className = "ModalBackdrop";
              function RestoreNonModal() {
              var dialog=$find('WebDialogWindow1');
                if(dialog.get_WindowState == "undefined"); {
                  //it's hidden
                  document.getElementById("ModalBackdrop").className = "";
          </script>
      And this div in my form area.
      <div id="ModalBackdrop" class=""></div>
      Here is the 16×16 png –>
        Arun
        Arun answered on Apr 6, 2009 11:06 AM
        Hi
        I have a question did you do this by setting the modal property to 'true' because i am trying to achieve something similar to this but with modla property being 'false'   can you help me on this
Michael Yarbrough
17 years, 4 months ago
Feb 12, 2026 8:55 AM
