Infragistics Community Forum / Web / Ignite UI for ASP.NET Core / Unable to create grid using Html.Infragistics().Grid() and get error "Unexpected token '<'
Pui Yee Poon
Pui Yee Poon asked on Jan 21, 2026 1:28 PM
I recently create a new .NET 6 web app project and want to use igGrid in my project. I was used to the C# MVC way (Html.Infragistics().Loader() $ Html.Infragistics().Grid()) to create the grid (instead of jquery way like $.ig.Loader & $(‘#id’).igGrid({})) but it return error “SyntaxError: Unexpected token ‘<‘, ” <script Ty”… is not valid JSON“.
Project structure, all IgniteUI css and js files are under wwwroot folder:
Nuget package: Infragistics.Web.AspNetCore (6.22.2.7)
The css and scripts referenced:
<link href=”/css/themes/infragistics/infragistics.theme.css” rel=”stylesheet” />
<link href=”/css/structure/infragistics.css” rel=”stylesheet” />
<script src=”“>code.jquery.com/…/script>
<script src=”/js/infragistics.core.js”></script>
<script src=”/js/infragistics.lob.js”></script>
<script src=”/js/infragistics.loader.js”></script>
Then, I have my controller code that return dummy records array to the Workbench.cshtml partial view.
Workbench.cshtml:
@using Infragistics.Web.Mvc
@model TestProjecte.Models.DummyModel
@(Html.Infragistics().Loader()
            .ScriptPath(Url.Content("/js/"))
            .CssPath(Url.Content("/css/"))
            .Theme("bootstrap")
            .Render())
@(Html.Infragistics().Grid(Model.Records.AsQueryable())
                .ID("tblRecords")
                .FixedHeaders(true)
                .DefaultColumnWidth("130px")
                .AutoGenerateColumns(false)
                .Columns(column =>
                    column.For(x => x.Id).HeaderText("Id").ColumnCssClass("text-center").HeaderCssClass("text-center");
                    column.For(x => x.StartTime).HeaderText("Start Time").ColumnCssClass("text-center").HeaderCssClass("text-center").DataType("date").Format("yyyy-MM-dd HH:mm:ss.fff").Width("200px");
                    column.For(x => x.EndTime).HeaderText("End Time").ColumnCssClass("text-center").HeaderCssClass("text-center").DataType("date").Format("yyyy-MM-dd HH:mm:ss.fff").Width("200px");
                    column.For(x => x.Dur).HeaderText("Duration (s)").ColumnCssClass("text-center").HeaderCssClass("text-center");
					column.For(x => x.Location).HeaderText("Location").ColumnCssClass("text-center").HeaderCssClass("text-center");
                .Virtualization(false)
                .Render())
May I know what did I miss out, is it missing Nuget package reference, wrong jquery version, or the way I use Html.Infragistics().Loader() is wrong (I was coming from .NET Framework project which creates the grid this way)? Any pointer or help is great, thanks!
    Pui Yee Poon
    Pui Yee Poon answered on Apr 10, 2023 6:19 AM
    My mistake, found out the issue was me declaring ajax call response data type 'json' which should really be 'html' since I'm returning a PartialView from controller.
    However, there's still issue with the grid, I can only see the table header and all rows are blank, there is an error coming from infragistics.ui.grid.filtering.js: "Cannot read properties of undefined (reading 'getEditor')" not sure if this is related?
      N. Ishibashi
      N. Ishibashi answered on Apr 10, 2023 9:40 AM
      I'm investigating your issue. When I have any update about it, I'll let you know. So could you wait for a while?
      Thank you in advance.
      N. Ishibashi
      N. Ishibashi answered on Apr 13, 2023 6:15 AM
      I have investigated your issue, and I have asked our engineering staff to examine this further.  To ensure that it will receive attention, I have logged this behavior in our internal tracking system with a Development ID of 275222. This will be assigned to a developer in a future sprint to review my investigation and confirm my findings or to offer a fix, or other resolution.
        N. Ishibashi
        N. Ishibashi answered on Apr 19, 2023 2:01 AM
        We investigated the issue and found out that it's solved by calling DataBind() before Render(), like this:
        .ID("tblRecords")
        @* … skipping some codes … *@
        .DataBind()
        .Render())
        Could you give it a try?
        Pui Yee Poon
        Pui Yee Poon answered on Apr 19, 2023 2:35 AM
        Tested and it is the missing DataBind() causing the issue, now I can see the full table. Thank you!
Pui Yee Poon
2 years, 11 months ago
Feb 25, 2026 9:51 AM
