Infragistics Community Forum / Web / Ignite UI for jQuery / get the column index from a key name
seang
seang asked on Mar 20, 2013 4:28 PM
Hello Stanislas,
What I can suggest for adding an unbound column in igGrid is adding it in the columns collection as following:
.Columns(col =>{    col.For(c => c.ProductID).HeaderText("ProductID");    .
   .    col.Unbound("Delete").HeaderText("Delete").DataType("string").Template("<input type='button' value='Delete row' onclick='deleteRow(${ProductID})' class='delete-button'/>");})
I believe you will find the following articles in our documentation useful:
I need to get the column index from a key as selectCell requires it but the ui only gives a key name?
columnSorting: function ( evt, ui )
_igGridSelection.clearSelection();
var col = ui.owner.grid.columnByText(ui.columnKey);
//how to get the column I'm in?????????????
var colIndex = 1;
for (var i = 0; i < ui.owner.grid.allRows().length; i++)
_igGridSelection.selectCell(i, colIndex);
return false;
    Maya Kirova
    Maya Kirova answered on Mar 20, 2013 3:00 PM
    Hello seang,
    To get the index you’ll need to loop through the columns of the igGrid and find the index in which the column with that key is located in the collection. For example:
    var currentRowInd = 0;
    for (var i = 0; i < columns.length; i++) {
      if (columns[i].key == ui.columnKey) {
          currentRowInd = i;
    Maya Kirova
    Developer Support Engineer II
      seang
      seang answered on Mar 20, 2013 3:42 PM
      I tried that approach but I never could find the total columns, nor a member that gave me an array of columns? Also are column keys unique? For example can two columns have the same name. Or is it considered best to keep a unique key but change the column text?
      key  1,2,3,4
      text  a,a,a,a
      this maybe clear it all up if my thinking is right.
        Maya Kirova
        Maya Kirova answered on Mar 20, 2013 4:26 PM
        Hello seang,
        The Key has to be unique. The text can be duplicated .
        It seems that when pasting the code snippet I missed one line:
            var columns = $("#grid").igGrid("option", "columns");
        This will return an array of the columns in the grid. You can use it to loop trough the columns.
        Maya Kirova
        seang
        seang answered on Mar 20, 2013 4:28 PM
        thx you!
seang
13 years, 5 months ago
Feb 24, 2026 8:00 AM
