Infragistics Community Forum / Web / Ignite UI for Angular / Module build failed: @include igx-dark-theme($green-palette); ^ No mixin named igx-dark-theme
shruti devurkar
shruti devurkar asked on Mar 1, 2021 2:52 PM
I am using angular 6 version hence i installed “igniteui-angular”: “6.2.0” and the feature I want to use is igxtexthighlightdirective.
After npm run build I am getting  following error:
No mixin named igx-dark-the.
Here is my style.scss
@import "~igniteui-angular/lib/core/styles/themes/index";
@include igx-core();
@include igx-theme($default-palette, $legacy-support: true);
:root {
  @include css-vars-from-palette($default-palette);
$green-palette: igx-palette(
  $primary: #09f,
  $secondary: #72da67,
  $surface: #333
.fin-dark-theme {
  background: #333;
  ::-moz-placeholder {
    opacity: 1;
.dark-theme {
  background: #333;
  color: #fff;
  @include igx-dark-theme($green-palette, $legacy-support: true);
  .grid-chart-contextmenu-wrapper {
    @include igx-fluent-dark-theme($fluent-excel-palette);
    Monika Kirkova
    Monika Kirkova answered on Feb 25, 2021 3:48 PM
    Hello Shruti,
    After investigating this further, I determined that the error message is displayed because the dark theme mixins are available since igniteui-angular version 7.0 and igx-fluent-dark-theme is introduced in version 8.2.
    Furthermore, please keep in mind that support is applicable to two versions back – latest stable, and the previous major version This means that version 6.2 is considered retired and it is no longer eligible for Developer Support Services. The current LTS is 11.1.0, which means that support is also applicable to 10.2.x.
    Monika Kirkova,
      shruti devurkar
      shruti devurkar answered on Feb 28, 2021 10:21 AM
      Then which theme is useable and will the functionality be still working?
        Monika Kirkova
        Monika Kirkova answered on Mar 1, 2021 2:52 PM
        Hello Shruti,
        Тhe default light theme could be used, however, version 6.2 is considered retired and it is no longer eligible for Developer Support Services.
        What I could suggest is upgrading to our latest version which at this point is version 11.1.
        Monika Kirkova,
    joyace hunter
    joyace hunter answered on May 14, 2026 10:11 AM
    The discussion around SCSS imports, mixins, and version compatibility is really useful for Angular developers working with Infragistics components. ezcardinfo
    marina Verbitska
    marina Verbitska answered on Jun 22, 2026 8:13 AM
    The Igx dark theme mixin error can be incredibly frustrating to debug, especially when dealing with Sass migration updates and breaking changes in Angular components. Troubleshooting complex stylesheet compilation issues requires a lot of technical focus. When my code is finally building and I need a quick mental break to step away from the IDE, I like to clear my head by checking out the latest sports action and the mr punter bonus code . Thanks for sharing this helpful fix!
shruti devurkar
1 month, 2 weeks ago
Mar 1, 2021 2:52 PM
Feb 25, 2026 8:47 AM
