Infragistics Community Forum / Web / Ignite UI for Angular / Getting Row Index while Pagination
Subham Ankit
Subham Ankit asked on Aug 19, 2020 12:01 PM
Hi All,
I have a Requirement where in i am displaying a igx-grid, which displays some columns as key values from JSON_A and a last column is a button which will actually open a dialog box to show the Complete JSON_A message from the row.
Now the issue is when we paginate this and the no of records in a page is restricted to 10. and we get around 50 records from api which we want to display in 5 pages.
Now First page works fine and gets the data in dialog as expected, but when we go to next page and click on the 2nd row button of second page to see 10(page 1)+2=12th  row index JSON data, it shows first page 2nd index data instead of showing 12th index JSON.
Ex:
The column for Button in the grid is as follows:
<igx-column [width]=”‘150px'” field=”action” header=”Action”>
            <ng-template igxCell let-cell=”cell”>
               <button mdbBtn color=”primary”  (click)=”getJSONData(cell)”>View Outbound</button>
            </ng-template>
</igx-column>
getJSONData(event:IgxGridCellComponent){
    const dataState1: IDataState2 = {
      key: event.rowIndex,
      rootLevel: false
  console.log(“index:”+dataState1.key);
  this.openAlertDialog(this.outboundUpdatesDataObject[dataState1.key]);
Interface:
export interface IDataState2 {
  key: number;
  rootLevel: boolean;
Can anyone help on how we can achieve this ?
A working Example would be very much helpful.
Subham
    Teodosia Hristodorova
    Teodosia Hristodorova answered on Aug 19, 2020 12:01 PM
    I have been looking into your requirement and created a simple sample in order to demonstrate how similar behavior could be achieved.
    For the purposes of the example, I added a column with buttons like in the provided description. And on button click, there is an alert showing the row index  (starting from 1). I was able to reproduce the behavior you are facing and it could be changed per your requirement by calculating the correct value using the igxGrid perPage and page properties. They return the numbers of items per page and the current page index. So, the key (row index) could be calculated as this.grid1.perPage * this.grid1.page + cell.rowIndex + 1.
    Here could be found my sample for your reference. Please test it on your side and let me know how it behaves. If this is not an accurate demonstration of what you are trying to achieve please feel free to modify it and send it back to me along with steps to reproduce.
Subham Ankit
6 years ago
Feb 20, 2026 9:40 PM
