Is there any way to change text color of igx-grid-cell based on text
New DiscussionI am using ignite ui for the first time in angular. I am facing some problem. Basically I have created library for ignite ui grid and consuming it. I want to make particular grid cell text color change based on text which i am passing in my grid columns like this( in 2nd object using property textColorChange and textColor)
field: 'ProductName',
resizable: true,
sortable: true,
filterable: true,
isTooltip: true,
isHtml: true,
field: 'QuantityPerUnit',
filterable: true,
sortable: true,
columnWidth: '200px',
textColorChange: true,
textColor: [{text: 'Success', color: 'green'},{text: 'Failure', color: 'red'}]
resizable: true,
sortable: true,
filterable: true,
isTooltip: true,
isHtml: true,
filterable: true,
sortable: true,
above object states that in column QuantityPerUnit if I found Success keyword then change the text color to green, same for Failure keyword also or any keyword.
This is I tried:
html
<igx-column
#col
*ngFor="let column of columns"
[field]="column.field"
[header]="column.title ? column.title : column.field"
[dataType]="column.dataType ? column.dataType : 'string'"
width="{{ column.columnWidth ? column.columnWidth : config.defaultColumnWidth }}"
[cellClasses]="column.textColorChange ? textColorChangeClasses: ''"
ts
private successTextColorCondition(rowData: any, columnKey: any): boolean {
return rowData[columnKey] === this.columns.forEach((text) => {
text.textColor['text']
private failureTextColorCondition(rowData: any, columnKey: any): boolean{
return rowData[columnKey] === 'Failure'
textColorChangeClasses = {
successText: this.successTextColorCondition
.scss
.successText {
color: $success-text-color
But I am getting error core.js:4352 ERROR TypeError: Cannot read property 'columns' of undefined
Is this correct way to do it? or is there any other way to achieve this.
I took help of this stackblitz https://stackblitz.com/github/IgniteUI/igniteui-live-editing-samples/tree/master/angular-demos/grid/grid-cell-styling
