Installing Microsoft Office 2007 UI Capabilties
New DiscussionI have to modify a years-old WinForms app that uses NetAdvantage WinForms 2012.2 with Office UI capabilities. I have run the NetAdvantage WinForms 2012.2 installer. The original source code builds, but running the app does not display the UltraToolbars ribbon. Opening the Design view in Visual Studio displays “This project uses the UltraToolbarsManager Ribbon and/or PopupGalleryTool. See “Installing Microsoft Office 2007 UI Capabilities” for more information.”
Found this link to a forum entry with the same problem: https://ko.infragistics.com/community/forums/f/ultimate-ui-for-windows-forms/107634/installing-netadvantage-winforms-2009-does-not-install-office-ui-capabilities
When running the installer, modify and/or repair and say yes to install the Office 2007 UI tools, never does a thing, says completed 0 of 0 and done.
Tried to uninstall and install again it but the result is the same.
Did you find the solution to the problem? Could you please share it with us?
