Infragistics Community Forum / Web / Ultimate UI for ASP.NET Web Forms / Label text not updating during OnRowSelectionChanged event
Adrian
Adrian asked on Apr 24, 2017 9:25 PM
I have a WebDataGrid with the OnRowSelctionChanged event configured.  In that event, I use server-side code to update the text on a label outside the grid.  I can see the lbl.Text value getting set on the server side, but it is not getting updated on the client side.
I have tried these approaches:
  • Put the grid and label inside an ASP Update Panel
  • Don’t use an UpdatePanel, but set EnableAjax and EnableAjaxViewState to True on the WebDataGrid.
  • Use a standard postback without the two above bullet points (no AJAX).
Is there anything I need to do to allow this event to update controls outside of the WebDataGrid?  If I run the same code using a standard ASP Button click (outside the grid), the label gets update appropriately.  So I must be misunderstanding something about the WebDataGrid event handling.
    Divya Jain
    Divya Jain answered on Apr 24, 2017 9:25 PM
    Hello Adrian,
    In the WebDataGrid during OnRowSelectionChanged event to set the label, you have to set ‘EnableAjax’ property to false to cause a full page postback in the page.
    To call the server method on the client side event ,you can handle the client side rowselectionchanged event and trigger a postback in this event like this:
    function WebDataGrid1_Selection_RowSelectionChanged(sender, eventArgs) {             if (eventArgs.getSelectedRows().get_length() > 0) {                 __doPostBack(‘<%= WebDataGrid1.ClientID %>’, ”);             }         }
    You can also refer the below post for more information:
    https://www.infragistics.com/community/forums/p/91681/453216.aspx#453216
Adrian
9 years, 5 months ago
Feb 20, 2026 11:35 AM
