Licenses.licx version
RIYAZ HUDDA
RIYAZ HUDDA asked on Jan 29, 2018 8:25 AM
When I installed version 2016.2 for winforms, I see Version=16.2.20162.2040 in my file, whereas my colleague sees Version=16.2.20162.1000
Is this going to be a problem when we check-in this and merge ? Will the deployment cause a problem?
    Plamena Miteva
    Plamena Miteva answered on Mar 17, 2017 2:46 PM
    Hello Riyaz,
    Using two different version of the Infragistics controls is not recommended or possible. Attempting to use multiple versions in a project will cause conflicts and the controls will not know what version of the assemblies to use. Your version (16.2.20162.2040) is the latest service release for WinForms. It includes several bug fixes, for which you can find more information here:
    https://www.componentsource.com/news/feature-releases/2017/01/16/infragistics-windows-forms
    Since you are using later version I would recommend that your colleague just upgrade to that version as well. There are several ways to upgrade. You can use Infragistics Project Upgrade Utility, which allows you to update any existing projects to the new version you are using or you can upgrade you solutions manually. You can find detailed information about the upgrading process on the following links:
    Version Utility:
    http://help.infragistics.com/Doc/WinForms/2014.1/CLR4.0/?page=Win_Upgrading_a_Project_to_Infragistics_Windows_Forms_11.1_(and_above)_Using_Version_Utility.html
    Manual Upgrade:
    http://help.infragistics.com/Doc/WinForms/2014.1/CLR4.0/?page=Win_Upgrading_a_Project_Manually.html
    I recommend using the tool instead of changing the project references yourself, since the tool handles some things you might not be aware of, like the licx files.
    Last option would be to uninstall all Infragistics files, then run the Platform Installer and on second step select Windows Forms and uncheck Service Release check box under Updates. This will install RTM version at his/her machine.
      Irina
      Irina answered on Jan 26, 2018 4:10 PM
      Hello Plamena.
      I need your help. I'm trying to upgrade Infragistics 13.1 to 14.1.
      So I've installed it, removed old references and added new. Clean, rebuild solution and receive an error message:
      Unable to resolve type 'Infragistics.Win.UltraWinEditors.UltraOptionSet, Infragistics4.Win.UltraWinEditors.v13.1, Version=13.1.20131.2105, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb'
      Do i need to update licences.licx file somehow?
      Thank you.
        Plamena Miteva
        Plamena Miteva answered on Jan 29, 2018 8:25 AM
        Hello Irina,
        If the reference to 'Infragistics.Win.UltraWinEditors.UltraOptionSet, Infragistics4.Win.UltraWinEditors.v13.1 remained in the licence.licx file, you can delete it from there and then clean and rebuild the solution again. Note that you have to delete only this reference, not the whole content of the license file.
        Please let me know if you need further assistance regarding this matter.
RIYAZ HUDDA
8 years, 1 month ago
Feb 23, 2026 5:37 PM
