Obtain data from checked rows in iggrid with checkboxes
New DiscussionHello,
I currently have a grid that stores the data of the selected row in an array when it is clicked. This method works perfectly fine, however I'm trying to change it so I can select multiple rows with a checkbox and be able to store all that date in my array. Basically, instead of adding one row at a time in my array, I want to be able to add multiple rows checked in it. I don't know if you guys follow me but please look into my code so we can find a way to do that.
Here it is :
$('#GridBindContact').on('iggridselectionactiverowchanged', function (event, args) {
$("#PrimaryKey").val(args.row.element[0].cells[1].textContent);
$("#ContactToBind_Numcon").val(args.row.element[0].cells[1].textContent);
$("#ContactToBind_FullName").val(args.row.element[0].cells[2].textContent + ' ' + args.row.element[0].cells[3].textContent);
$("#ContactToBind_Titcon").val(args.row.element[0].cells[4].textContent);
$("#ContactToBind_Tel1con").val(args.row.element[0].cells[5].textContent);
$("#ContactToBind_Tel2con").val(args.row.element[0].cells[5].textContent);
$("#ContactToBind_Emailcon").val(args.row.element[0].cells[7].textContent);
$("#ContactToBind_NumEmployees").val(args.row.element[0].cells[8].textContent);
$("#ContactToBind_NameEmployees").val(args.row.element[0].cells[9].textContent);
$("#ContactToBind_Added").val(true);
$(".ui-button-text").trigger("click");
AutoGenerateColumns(False).
Width("100%").
Height("400px").
ResponseDataKey("Results").
Columns(Sub(column)
column.For(Function(e) e.Numcon).Template("${Numcon}").HeaderText("Num")
column.For(Function(e) e.Pnmcon).Template("${Pnmcon}").HeaderText("Pnm").Width("10%")
column.For(Function(e) e.Namemcon).Template("${Namecon}").HeaderText("Name").Width("15%")
column.For(Function(e) e.Titcon).Template("${Titcon}").HeaderText("Title").Width("20%")
column.For(Function(e) e.Tel1con).Template("${Tel1con}").HeaderText("Tel1")
column.For(Function(e) e.Tel2con).Template("${Tel2con}").HeaderText("Tel2")
column.For(Function(e) e.Emailcon).Template("${Emailcon}").HeaderText("Email")
column.For(Function(e) e.NumEmployees).HeaderText("Num Emp")
column.For(Function(e) e.NameEmployees).HeaderText("Name Emp")
End Sub).
Features(Sub(features)
features.Sorting().Type(OpType.Local)
features.RowSelectors.EnableCheckBoxes(True).RowSelectorsColumnWidth("50px").EnableRowNumbering(False)
features.Selection().Mode(SelectionMode.Row).MultipleSelection(True).AddClientEvent("activeRowChanging", "activeRowChanging")
features.Updating().EditMode(GridEditMode.None).EnableAddRow(False).EnableDeleteRow(False)
End Sub).Render())
<form action="#" id="ajaxForm" method="post">
@Html.HiddenFor(Function(x) x.PrimaryKey)
@Html.HiddenFor(Function(x) x.ContactToBind.Numcon)
@Html.HiddenFor(Function(x) x.ContactToBind.FullName)
@Html.HiddenFor(Function(x) x.ContactToBind.Titcon)
@Html.HiddenFor(Function(x) x.ContactToBind.Tel1con)
@Html.HiddenFor(Function(x) x.ContactToBind.Tel2con)
@Html.HiddenFor(Function(x) x.ContactToBind.Emailcon)
@Html.HiddenFor(Function(x) x.ContactToBind.NumEmployees)
@Html.HiddenFor(Function(x) x.ContactToBind.NameEmployees)
</form>
I already added the feature to have checkboxes in my grid, but got nothing to handle them yet !
Thanks alot for your help,
Guillaume
