Gird – how to get the Id value from MVC controller back to grid?
New DiscussionHi
I am trying to get my first MVC website (and first use of jQuery) up and running with the Ignite grid. I have read many articles and posts but am now stuck with my batch updates.
I have a grid in my MVC view which uses UpdateURL to save its data. The view includes code to generate a temporary PrimaryKey (as described in the “Adding a PrimaryKey for the AddNewRow” section of the same article) for the new row and when the Save button is clicked the UpdateURL is followed to my controller to carry out the update.
The bit that stumps me is that the various Infragistics articles have a similar technique to get the temporary id in the view but this obviously cannot be the ID that is eventually created by the controller (since, in my case, it is a self incrementing IDENTITY column in SQL SERVER and is only defined when the record is INSERTed into the DB) so the view cannot be in charge of which IDs are used.
The controller can easily save the new record, which is then automatically assigned the new ID (I am using Entity Framework for this bit) but how do I get the new ID back to the grid from UpdatingSaveChanges so that when the user decides to delete the record they just saved the controller is presented with the new ID instead of the temporary one?
For me, it goes bang every time because my temporary IDs are negative and the real IDs are positive so the controller will never find the temporary ID in the DB.
I have tried setting the rowID and LookupCodeID in UpdatingSaveChanges but the values don’t get back to the grid.
I am sure that I am missing something elementary because web development is all new to me and would appreciate some help.
View code:
@using (Html.BeginForm())
<script type="text/javascript" >
$.ig.loader(function () {
var lookupCodeID_forNewRow = -1;
// event raised after edit cell started
$("#LUCGrid").live("iggridupdatinggenerateprimarykeyvalue", function (event, ui) {
ui.value = lookupCodeID_forNewRow--;
$("#LUCGrid").live("iggridupdatingeditcellstarted", function (event, ui) {
if (!ui.editor) {
return;
if (ui.key === 'LookupCodeID') {
ui.editor.igEditor('option', 'readOnly', true);
$("#LUCGrid").live("iggridupdatingdatadirty", function (event, ui) {
$("#LUCGrid").igGrid("commit");
return false;
$("#LUCGrid").live("iggridupdatingrowadding", function (event, ui) {
ui.values["LookupTypeID"] = (@Model.LookupTypeID);
</script>
<fieldset>
<div class="LookupCodeTable" >
@Html.ValidationSummary(true)
@(Html.Infragistics()
.Grid(Model.LookupCodes.AsQueryable())
.ID("LUCGrid")
.Height("500px")
.Width("500px")
.PrimaryKey("LookupCodeID")
.AutoCommit(false)
.AutoGenerateColumns(false)
.AutoGenerateLayouts(true)
.Columns(column =>
column.For(x => x.LookupCodeID).DataType("numeric");
column.For(x => x.Code).HeaderText("Code");
column.For(x => x.Description).HeaderText("Description");
.Features(features =>
features.Sorting().Type(OpType.Remote);
features.Paging().DefaultDropDownWidth("90px").PageSize(10).Type(OpType.Remote);
features.Filtering().Type(OpType.Remote);
features.Hiding().ColumnSettings(settings =>
settings.ColumnSetting().ColumnKey("LookupCodeID").Hidden(false).AllowHiding(false);
features.Updating()
.ShowReadonlyEditors(false)
.EditMode(GridEditMode.Row)
.EditorType(ColumnEditorType.Text)
.Required(true)
.ReadOnly(true)
.Validation(true);
settings.ColumnSetting().ColumnKey("Code")
.Required(true)
.Validation(true);
settings.ColumnSetting().ColumnKey("Description")
.Required(true)
.Validation(true);
.AddRowTooltip(string.Format("Click this row to add new {0} code", Model.ShortDescription))
.AddRowLabel(string.Format("Add new {0} code", Model.ShortDescription));
.UpdateUrl(Url.Action("UpdatingSaveChanges"))
.DataSourceUrl(Url.Action(CodesController.GRID_GetLookupCodesForType, new { inlookupTypeID = Model.LookupTypeID }))
.Render()
</div>
<p>
<input type="button" id="saveChanges" value="Save" />
</p>
</fieldset>
<script type="text/javascript" src="../../Scripts/LookupCodes.js">
</script>
Controller code:
public ActionResult UpdatingSaveChanges()
ViewData["GenerateCompactJSONResponse"] = false;
GridModel m = new GridModel();
List<Transaction<wsLookupCode>> transactions = m.LoadTransactions<wsLookupCode>(HttpContext.Request.Form["ig_transactions"]);
string strResult = string.Empty;
foreach (Transaction<wsLookupCode> oTx in transactions)
if (clsiGridHelper.GetTransactionType(oTx.type) == clsiGridHelper.TransactionRowType.New)
LookupCode oLUC = new LookupCode();
oLUC.Code = clsStringHelper.GetString(oTx.row.Code);
oLUC.DefaultValue = clsStringHelper.GetString(oTx.row.DefaultValue);
oLUC.Description = clsStringHelper.GetString(oTx.row.Description);
oLUC.LookupTypeID = oTx.row.LookupTypeID;
LUCRepository.Add(oLUC);
strResult = UoW.Save();
if (strResult.Length == 0)
oTx.row.LookupCodeID = oLUC.LookupCodeID;
oTx.rowId = oTx.row.LookupCodeID.ToString();
else if (clsiGridHelper.GetTransactionType(oTx.type) == clsiGridHelper.TransactionRowType.Deleted)
LookupCode oLUC = LUCRepository.GetByID(Convert.ToInt64(oTx.rowId));
if (oLUC != null & !oLUC.IsDeleted)
oLUC.IsDeleted = true;
}// got LUC??
else if (clsiGridHelper.GetTransactionType(oTx.type) == clsiGridHelper.TransactionRowType.Row)
LookupCode oLUC = LUCRepository.GetByID(oTx.row.LookupCodeID);
if (oLUC != null)
if (oTx.row.Code != null && oLUC.Code != oTx.row.Code)
oLUC.Code = oTx.row.Code;
if (oTx.row.Description != null && oLUC.Description != oTx.row.Description)
oLUC.Description = oTx.row.Description;
if (oTx.row.DefaultValue != null && oLUC.DefaultValue != oTx.row.DefaultValue)
oLUC.DefaultValue = oTx.row.DefaultValue;
}// got LUC??
}// row type
}// each transaction
JsonResult result = new JsonResult();
Dictionary<string, bool> response = new Dictionary<string, bool>();
response.Add("Success", true);
else
response.Add(strResult, false);
result.Data = response;
return result;
}// UpdatingSaveChanges
