SassError: semicolons aren't allowed
New DiscussionI upgraded my angular 10 app to 11. I also upgraded igniteui-cli to the latest. I ran the command ng add igniteui-angular to integrate igniteui to the app.
The styles.sass file looks like below. When I run the command npm start, I get the following error.
// CSS Reset, comment out if not required or using a different module @import '~minireset.css/minireset'; /* You can add global styles to this file, and also import other style files */ @import "~igniteui-angular/lib/core/styles/themes/index"; // Uncomment the following lines if you want to add a custom palette: // $primary: #731963 !default; // $secondary: #ce5712 !default; // $app-palette: igx-palette($primary, $secondary); /* autoprefixer grid: on */ @include igx-core(); @include igx-theme($default-palette);
SASS Error:
Error: ./src/styles.sass Module build failed (from ./node_modules/mini-css-extract-plugin/dist/loader.js): ModuleBuildError: Module build failed (from ./node_modules/sass-loader/dist/cjs.js): SassError: semicolons aren't allowed in the indented syntax. ╷ 5 │ @import "~igniteui-angular/lib/core/styles/themes/index"; │ ^ ╵ src\styles.sass 5:57 root stylesheet
package.json contents:
"dependencies": {
"@angular/animations": "^11.0.2",
"@angular/common": "^11.0.2",
"@angular/compiler": "^11.0.2",
"@angular/core": "^11.0.2",
"@angular/forms": "^11.0.2",
"@angular/platform-browser": "^11.0.2",
"@angular/platform-browser-dynamic": "^11.0.2",
"@angular/router": "^11.0.2",
"@datorama/akita": "^4.23.2",
"@datorama/akita-ng-entity-service": "^1.0.0",
"@igniteui/material-icons-extended": "^2.4.0",
"hammerjs": "^2.0.8",
"igniteui-angular": "^11.0.3",
"jszip": "^3.5.0",
"minireset.css": "~0.0.4",
"resize-observer-polyfill": "^1.5.1",
"rxjs": "~6.6.0",
"tslib": "^2.0.0",
"web-animations-js": "^2.3.2",
"zone.js": "~0.10.2"
"devDependencies": {
"@angular-devkit/build-angular": "^0.1100.2",
"@angular/cli": "^11.0.2",
"@angular/compiler-cli": "^11.0.2",
"@datorama/akita-ng-router-store": "^3.1.3",
"@datorama/akita-ngdevtools": "^3.0.2",
"@igniteui/angular-schematics": "~11.0.700",
"@types/hammerjs": "^2.0.36",
"@types/jasmine": "~3.6.0",
"@types/jasminewd2": "~2.0.3",
"@types/node": "^12.19.6",
"codelyzer": "^6.0.0",
"jasmine-core": "~3.6.0",
"jasmine-spec-reporter": "~5.0.0",
"karma": "~5.1.1",
"karma-chrome-launcher": "~3.1.0",
"karma-coverage-istanbul-reporter": "~3.0.2",
"karma-jasmine": "~4.0.0",
"karma-jasmine-html-reporter": "^1.5.0",
"protractor": "~7.0.0",
"ts-node": "~8.3.0",
"tslint": "~6.1.0",
"typescript": "^4.0.5"
Sign In
to post a reply
1 Created On
Nov 24, 2020 Last Post
5 years, 8 months ago
