Infragistics Community Forum / Web / Ignite UI for jQuery / How to set value to a datepicker through Javascript ()???
Kishore A
Kishore A asked on Jul 8, 2014 8:05 AM
My JAVASCRIPT Function in View:
$(function () {
function ProgrammeAllotmentModel() {
this.ProposalDetailsIDKey = “”;
$(document).delegate(“.ddlProposalDetail”, “igcomboselectionchanged”,
function (evt, ui) {
var id = evt.target.id;
if (ui.items && ui.items[0]) {
var myRecipe = new ProgrammeAllotmentModel();
myRecipe.ProposalDetailsIDKey = ui.items[0].value;
var postData = JSON.stringify(myRecipe);
$.ajax({
url: ‘@Url.Action(“/LoadProposalDetailsByIDKey”)’,
type: ‘POST’,
data: JSON.stringify(myRecipe),
dataType: ‘json’,
contentType: ‘application/json; charset=utf-8’,
success: function (obj) {
var num = id.replace(“ddlProposalDetail”, “”);
alert(num);
$.each(obj, function (key, value) {
alert(value.TentativeFromDateDt);
$(“#TentativeStartDate” + num).igDatePicker(value.TentativeFromDateDt, new Date());
error: function () {
alert(‘error occured’);
</script>
Am rendering a partial view which has a datepicker in it.
My partial view :
<td>
@Html.Infragistics().DatePickerFor(model => model.MyProperty[j].TentativeStartDate).ID(“TentativeStartDate” + j).DateInputFormat(“dd/MM/yyyy”).Width(100).Height(22).ValidatorOptions(m => m.Required(false)).Render()
</td>
My controller function returns  TentativeFromDateDt  Property as {6/25/2014 9:34:59 PM}
Mt model class contains
public Nullable<System.DateTime> TentativeFromDateDt { get; set; }
My alert box in  javascript ()  shows:
/Date(1403712299050)/
    Maya Kirova
    Maya Kirova answered on Jul 7, 2014 8:28 AM
    Hello Kishore ,
    The value can be set via the igEditor widget using the “value” method. For example:
    $(".selector").igEditor("value", new Date(1403712299050));
    For more details refer to our API documentation:
    http://help.infragistics.com/jQuery/2014.1/ui.igeditor#methods
    All editors inherit from the igEditor widget and their values need to be set through it.
    Maya Kirova
    Developer Support Engineer II
      Kishore A
      Kishore A answered on Jul 8, 2014 8:05 AM
      I heartily Thank You Maya Kirova.
      But it is shoing something like " N/Nan/0Nan"
      but I somehow managed to bring the desired output by setting the value through
      $(".selector").igEditor("value", new Date(value.TentFrmDt));
      where :
      IN Model
      public string TentFrmDt { get; set; } and
      and
      IN Controller
       TentFrmDt=String.Format("{0:d}", TentativeFromDateDt);
Kishore A
11 years, 8 months ago
Jul 8, 2014 8:05 AM
Feb 12, 2026 9:17 AM
