Infragistics Community Forum / Web / Ignite UI for React / React Spreadsheet: Not able to render excel with charts on example page
Kaveri InfraM
Kaveri InfraM asked on Feb 4, 2022 5:24 PM
Hi All ,
When I try the example as given on your page https://ko.infragistics.com/products/ignite-ui-react/react/components/spreadsheet-overview
with an excel with charts. the output ui is not able to render the chart but I just see chart data.
My particular requirement is to create a read only excel viewer on my react web page that should render excel files as is (i.e. along with charts graphs images and all) .
Please let me know if this is possible via Ignite UI libraries.
Kaveri M.
    Michael DiFilippo
    Michael DiFilippo answered on Jan 25, 2022 4:16 PM
    Hello and thank you for contacting Infragistics. Our Excel API lets you add charts to the Spreadsheet using our chart adapter module. It can also import/export charts to and from the spreadsheet and Excel.
    eg. Export a standalone chart to Excel
    https://ko.infragistics.com/reactsite/components/excel-library-working-with-charts
    eg. Load a chart in the Spreadsheet
    https://ko.infragistics.com/reactsite/components/spreadsheet-chart-adapter
    You may use the CodeSandbox buttons to see the code. If you want to debug the applications I would use the down arrow in the editor in the left pane to download the projects locally and run them that way then rely on the editor.
      Kaveri InfraM
      Kaveri InfraM answered on Feb 3, 2022 8:26 AM
      Hi ,
      Thanks for this Information.
      We tried to implement the same but when we try to open large spreadsheets ~5mb in size the app fails to render the same on UI .
      Pls check following code in Exceluitlity
      Workbook.load(data, new WorkbookLoadOptions(), (w) => {
      resolve(w);
      }, (e) => {
      reject(e);
      We are getting this error :
      Index was out of range. It must be non-negative and less than the size of the collection.
        Michael DiFilippo
        Michael DiFilippo answered on Feb 3, 2022 3:08 PM
        It appears the codesandbox samples are missing our layouts package. It will prompt you to add it and after a refresh it will eventually load the sample. eg. https://codesandbox.io/s/lucid-curie-qz04z
        If you wish to dive into this locally, you can access the source of the sample here
        https://github.com/IgniteUI/igniteui-react-examples/tree/vnext/samples/excel/excel-library/working-with-charts
        This repository contains links to codesandbox and live demos that is hosted in our documentation
        Kaveri InfraM
        Kaveri InfraM answered on Feb 3, 2022 5:06 PM
        Hi Michael ,
        I have observed an issue with rendering charts on .xls files.
        As you can see in the screenshot I am getting a black spot in the middle of excel.
        Also adding the code.
        import React from 'react';
        import ReactDOM from 'react-dom';
        import './index.css';
        import { ExcelUtility } from './ExcelUtility';
        import { IgrExcelXlsxModule } from 'igniteui-react-excel';
        import { IgrExcelCoreModule } from 'igniteui-react-excel';
        import { IgrExcelModule } from 'igniteui-react-excel';
        import { IgrSpreadsheetModule } from 'igniteui-react-spreadsheet';
        import { IgrSpreadsheet } from 'igniteui-react-spreadsheet';
        import { IgrSpreadsheetChartAdapterModule } from 'igniteui-react-spreadsheet-chart-adapter';
        import { SpreadsheetChartAdapter } from 'igniteui-react-spreadsheet-chart-adapter';
        import { Worksheet } from 'igniteui-react-excel';
        import { WorksheetCell } from 'igniteui-react-excel';
        import { ChartType, ChartTitle, FormattedString } from 'igniteui-react-excel';
        IgrExcelCoreModule.register();
        IgrExcelModule.register();
        IgrExcelXlsxModule.register();
        IgrSpreadsheetModule.register();
        IgrSpreadsheetChartAdapterModule.register();
        export default class SpreadsheetAdapterForCharts extends React.Component {
        public spreadsheet: IgrSpreadsheet;
        constructor(props: any) {
        super(props);
        this.onSpreadsheetRef = this.onSpreadsheetRef.bind(this);
        public render(): JSX.Element {
        return (
        <div className="container sample">
        <div className="options horizontal">
        <input type="file" onChange={(e) => this.openFile(e.target.files as FileList)} accept=".xls, .xlt, .xlsx, .xlsm, .xltm, .xltx"/>
        </div>
        <IgrSpreadsheet ref={this.onSpreadsheetRef} height="calc(100% - 30px)" width="100%" />
        </div>
        public openFile(selectorFiles: FileList) {
        if (selectorFiles != null && selectorFiles.length > 0) {
        ExcelUtility.load(selectorFiles[0]).then((w) => {
        this.spreadsheet.workbook = w;
        }, (e) => {
        console.error("Workbook Load Error");
        public onSpreadsheetRef(spreadsheet: IgrSpreadsheet) {
        if (!spreadsheet) { return; }
        this.spreadsheet = spreadsheet;
        this.spreadsheet.chartAdapter = new SpreadsheetChartAdapter();
        const url = "https://static.infragistics.com/xplatform/excel/SalesData.xlsx"
        ExcelUtility.loadFromUrl(url).then((w) => {
        if (spreadsheet) {
        const url = "https://static.infragistics.com/xplatform/excel/ChartData.xlsx";
        // ExcelUtility.loadFromUrl(url);
        const sheet: Worksheet = this.spreadsheet.workbook.worksheets(0);
        sheet.defaultColumnWidth = 450 * 20;
        sheet.rows(0).height = 150 * 20;
        const cell1: WorksheetCell = sheet.getCell("A1");
        const cell2: WorksheetCell = sheet.getCell("B1");
        const cell3: WorksheetCell = sheet.getCell("C1");
        const cell4: WorksheetCell = sheet.getCell("D1");
        const dataCellAddress = "A3:D6";
        const title: ChartTitle = new ChartTitle();
        title.text = new FormattedString("Line Chart");
        const chart1 = sheet.shapes().addChart(ChartType.Line, cell1, { x: 5, y: 5 }, cell1, { x: 90, y: 90 });
        chart1.chartTitle = title;
        chart1.setSourceData(dataCellAddress, true);
        const title2: ChartTitle = new ChartTitle();
        title2.text = new FormattedString("Column Chart");
        const chart2 = sheet.shapes().addChart(ChartType.ColumnClustered, cell2, { x: 5, y: 5 }, cell2, { x: 90, y: 90 });
        chart2.chartTitle = title2;
        chart2.setSourceData(dataCellAddress, true);
        const title3: ChartTitle = new ChartTitle();
        title3.text = new FormattedString("Area Chart");
        const chart3 = sheet.shapes().addChart(ChartType.Area, cell3, { x: 5, y: 5 }, cell3, { x: 90, y: 90 });
        chart3.chartTitle = title3;
        chart3.setSourceData(dataCellAddress, true);
        const title4: ChartTitle = new ChartTitle();
        title4.text = new FormattedString("Pie Chart");
        const chart4 = sheet.shapes().addChart(ChartType.Pie, cell4, { x: 5, y: 5 }, cell4, { x: 90, y: 90 });
        chart4.chartTitle = title4;
        chart4.setSourceData(dataCellAddress, true);
        // rendering above class to the React DOM
        ReactDOM.render(<SpreadsheetAdapterForCharts />, document.getElementById('root'));
        Actual file looks like this ->
        Is it like this utility only supports .xlsx files?
        Michael DiFilippo
        Michael DiFilippo answered on Feb 3, 2022 6:35 PM
        Can you point out the black spot artifact you are mentioning? I cannot tell from your screenshots. Preferably, please modify the sample I linked above and attach it.
        Kaveri InfraM
        Kaveri InfraM answered on Feb 4, 2022 5:41 AM
        Hi Michael
        Apologies, Its a Typo. I am referring to a blank spot / area in the middle of screen .
        PFA screenshot
        Ideally a colored chart must appear in the blank area like below.
        Code sandbox link
        https://codesandbox.io/s/github/IgniteUI/igniteui-react-examples/tree/master/samples/excel/spreadsheet/adapter-chart?fontsize=14&hidenavigation=1&theme=dark&view=preview&file=/src/index.tsx
        Also sharing Sample file I used .
        Michael DiFilippo
        Michael DiFilippo answered on Feb 4, 2022 5:24 PM
        Hello and thank you for following up.
        3d Charts are not supported chart types. Please submit and new product idea.
        I changed your chart type to a normal cluster bar and it's not loading in the spreadsheet. I logged a development issue and opened a support ticket for you. C-00222016
        You can access it after signing into your account on the Infragistics website, here: https://account.infragistics.com/support-cases
        You can suggest new product ideas for future versions (or vote for existing ones) at
        Remember when submitting your idea to explain the context in which a feature would be used and why it is needed as well as anything that would prevent you from accomplishing this today. You can even add screenshots to build a stronger case. Remember that for your suggestion to be successful, you need other members of the community to vote for it.
Kaveri InfraM
4 years, 7 months ago
Feb 4, 2022 5:24 PM
Feb 19, 2026 4:31 PM
