Multi Selection in ultracombo
Syed
Syed asked on Jul 13, 2017 8:45 AM
Hello All,
I am using infragistic 12.2 ultracombo as multi selection by using its properties stated below :
void ultraMultiCombo() {
          //Add an additional unbound column to WinCombo.
          //This will be used for the Selection of each Item
          UltraGridColumn c = this.ultraCombo1.DisplayLayout.Bands[0].
Columns.Add();
          c.Key = "Selected";
          c.Header.Caption = string.Empty;
          //This allows end users to select / unselect ALL items
          c.Header.CheckBoxVisibility = HeaderCheckBoxVisibility.
Always;
          c.DataType = typeof(bool);
          //Move the checkbox column to the first position.
          c.Header.VisiblePosition = 0;
          this.ultraCombo1.CheckedListSettings.CheckStateMember =
 "Selected";
          this.ultraCombo1.CheckedListSettings.EditorValueSource =
Infragistics.Win.EditorWithComboValueSource.CheckedItems;
          // Set up the control to use a custom list delimiter
          this.ultraCombo1.CheckedListSettings.ListSeparator = " / ";
          // Set ItemCheckArea to Item, so that clicking directly
on an item also checks the item
          this.ultraCombo1.CheckedListSettings.ItemCheckArea =
Infragistics.Win.ItemCheckArea.Item;
          this.ultraCombo1.DisplayMember = "Name";
          this.ultraCombo1.ValueMember = "Age";
And getting checked values by
string s = string.Empty;
          foreach (UltraGridRow r in this.ultraCombo1.CheckedRows)
              s += r.Cells["Name"].Value.ToString() + Environment.NewLine;
the problem is that whenever i check multi records and click on button
 to show multiple values through above code its correctly but in ultracomboa
 selected values not dispaying, as shown in image below:
    Plamena Miteva
    Plamena Miteva answered on May 26, 2017 4:11 PM
    Hello Syed,
    I have created a sample using the code you provided. When I run the project and I check some items from the UltraCombo, they are displayed exactly as expected (example: Maria / John / Peter).
    I have attached the sample project I used to test this.  Please, feel free to make the sample that I provided more like your application and send it back in case it does not replicate your steps.
      Syed
      Syed answered on May 26, 2017 4:31 PM
      Hey Plamena Miteva
      I got it and my issue has been resolved thanks alot for helping.
      issue in my code was the datasource i provided and incorrect type of column which was bound.
      (please excuse my english as i am not fluent in it)
      Thanks & Regards
      Syed Wahhab.
        Peter
        Peter answered on Jul 13, 2017 8:45 AM
Syed
8 years, 8 months ago
Feb 18, 2026 8:07 AM
