Infragistics Community Forum / Desktop / Ultimate UI for Windows Forms / Set UltraGrid Header Alignment and Hide Child Bands
Reyian
Reyian asked on Oct 23, 2008 2:51 PM
anyone?
and one more thing, i have set the datasource at runtime.
each item in that source has a list of other objects, it turns out that
the grid displays child bands for each of the list members, where
I can expand and unexpand. How to prevent that from displaying.
    Andrew
    Andrew answered on Oct 21, 2008 3:05 PM
    grid.DisplayLayout.Override.ExpansionIndicator = ShowExpansionIndicator.Never;
    Mike Saltzman answered on Oct 21, 2008 4:03 PM
    What exactly do you mean by the alignment of the column header? Do you mean the alignment of the text in the header? That's controlled by the HeaderAppearance. There's properties on the appearance for TextVAlign, TextHAlign, ImageVAlign, and ImageHAlign.
      Reyian
      Reyian answered on Oct 22, 2008 3:43 AM
      Yes the text in the column header, I think by default it is Center, I want it to be left align.
      I write this code in the grid InitializeLayout method
      e.Layout.Bands[0].Columns["colKey"]…… header text left align. I dont know how to do it.
      And how can I set the utragrid to multiselect rows, and then how can I get the objects in the
      selected rows? Thanks in advance and more power.
        Arun Rajaraman
        Arun Rajaraman answered on Oct 22, 2008 7:44 AM
        Hi …
        ''for header text alignment
        UltraGrid1.DisplayLayout.Bands(0).Override.HeaderAppearance.TextHAlign = Infragistics.Win.HAlign.Left
        ''to multiselect rows
        e.Layout.Override.CellClickAction = Infragistics.Win.UltraWinGrid.CellClickAction.RowSelect
        UltraGrid1.DisplayLayout.Bands(0).Override.SelectTypeRow = Infragistics.Win.UltraWinGrid.SelectType.Extended
        Reyian
        Reyian answered on Oct 22, 2008 9:32 AM
         Wheeeewww!! Awesome, Thanks
        One more thing, how can I manipulate the order of the columns
        in the grid, im binding the data source at runtime.
        Mike Saltzman answered on Oct 22, 2008 2:30 PM
        You can set the column.Header.VisiblePosition.
        The InitializeLayout event is a good place to do all of this.
        Reyian
        Reyian answered on Oct 23, 2008 2:21 AM
         Thank you. I have one more problem and I cant figure out the solution.
         Im supplying the data source at runtmine (it is an IList). Everytime I remove
        an Item to that List the grid updates(remove row) but when I added Item to the
        List, the grid doesn't update (no new row being created).
        I tried the Update and UpdateData in the grid but nothings happen.
        How I am going to do this?
        Andrew
        Andrew answered on Oct 23, 2008 2:51 PM
        The IList interface doesn't support notifications for changes in data such as changes in cell values, adding or removing of rows, etc. Therefore if you want to support these operations in your data source then it is recommended that you implement the .NET IBindingList interface or use BindingList instead, which has support for notifying the bound controls of such changes.
Reyian
17 years, 11 months ago
Feb 11, 2026 8:09 PM
