Infragistics Community Forum / Cross Platform / Ultimate UI for Xamarin / The string parameter 'key' cannot be null or empty. Parameter name: key
Pete Sral
Pete Sral asked on Sep 15, 2015 7:21 PM
I’ve attached a sample project, inside the zip file is an overview.txt file that explains what we are trying to do in more detail.
How to reproduce:
If you start running the application and immediately click the search button – you see a postback and the results in the textboxes are displayed in the status textbox below:
But if you start the application and click around with the navigation controls (or select different rows on the grid) and then click on the search button – you get the following exception that appears to be coming from the grid control:
The string parameter ‘key’ cannot be null or empty.
Parameter name: key
Exception Details: System.ArgumentException: The string parameter ‘key’ cannot be null or empty.
Parameter name: key
Source Error:
Stack Trace:
[ArgumentException: The string parameter ‘key’ cannot be null or empty.
Parameter name: key]
System.Web.UI.StateBag.get_Item(String key) +8820932
Infragistics.Web.UI.Framework.Data.DataRecord.GetValue(String fieldName) +87
Infragistics.Web.UI.GridControls.ControlDataRecord.GetValue(ControlDataField field) +240
Infragistics.Web.UI.GridControls.ControlDataItemCollection.GetValue(Int32 index) +207
Infragistics.Web.UI.GridControls.ControlDataItemCollection.GetValue(ControlDataItem item) +71
Infragistics.Web.UI.GridControls.ControlDataItem.get_Value() +47
Infragistics.Web.UI.GridControls.GridRecordItem.GetTextNode() +154
Infragistics.Web.UI.GridControls.ControlDataItem.Infragistics.Web.UI.GridControls.IXPathDataNavigableObject.get_Xml() +156
Infragistics.Web.UI.GridControls.XPathDataNavigable.GetNextSibling() +43
Infragistics.Web.UI.GridControls.XPathDataNavigator.MoveToNext() +87
Infragistics.Web.UI.GridControls.XPathDataNavigator.OutputToStream(XPathDataNavigator xpdn, XmlTextWriter stream, HtmlTextWriter htmlWriter) +329
Infragistics.Web.UI.GridControls.XPathDataNavigator.OutputToStream(XPathDataNavigator xpdn, XmlTextWriter stream, HtmlTextWriter htmlWriter) +318
Infragistics.Web.UI.GridControls.XPathDataNavigator.get_OuterXml() +199
Infragistics.Web.UI.GridControls.GridRenderer.RenderContents(HtmlTextWriter writer) +1251
SampleWebDataGrid
    [Infragistics] Michael H.
    [Infragistics] Michael H. answered on Oct 16, 2012 10:00 PM
    Dear Pete (BSC),
    We have received your support request concerning your "string parameter 'key' cannot be null or empty" error, and this case has been assigned to me.  Infragistics is dedicated to helping you solve this issue.  Our team and I have done an initial review of your case and
    I am looking into your sample and will get back to you by Friday with more information or questions for you.
    If you have any questions or concerns with this, please let me know and I'll be glad to help.
      [Infragistics] Michael H. answered on Oct 19, 2012 9:39 PM
      Hi Pete (BSC),
      I'm updating you to let you know that I'm able to reproduce the issue.  I've found, so far, that this exception is being triggered when trying to access a BoundDataField "Field 9" which does not have a key assigned to it.  I need some more time to research why this is occurring.  I will have another update for you by Wednesday.
        [Infragistics] Michael H. answered on Oct 24, 2012 9:52 PM
        Hi Pete (BSC),
        I need a little more time to research this issue.  I will have another update for you sometime tomorrow.
        [Infragistics] Michael H. answered on Oct 25, 2012 5:37 PM
        Hi Pete (BSC),
        This issue is being caused by the call to WebDataGrid1.ClearDataSource() in your ClearDataGrid() method.  ClearDataSource() needs to be called when assigning a new DataSource to the grid.  Since you're setting it to Nothing, there's no need to call ClearDataSource and this is causing the grid to think it has more columns than it should.
        For more information on ClearDataSource, please see the following documentation:
        http://help.infragistics.com/NetAdvantage/ASPNET/2012.2/CLR4.0/?page=Infragistics4.Web.v12.2~Infragistics.Web.UI.GridControls.WebDataGrid~ClearDataSource.html
        If you have any further questions or concerns with this issue, please let me know and I'll be glad to help.
        [Infragistics] Michael H. answered on Oct 31, 2012 8:24 PM
        Hello Pete (BSC),
        Please let me know if you have any other questions or concerns about this issue and I'll be glad to help you.
        Dana Crosby
        Dana Crosby answered on Feb 28, 2013 4:16 PM
        I'm getting the same error on a page with 2 grids. Both are bould to a non-persistent DataSource (SQL DataSet) on button click.
        Grid_1 has DataViewState enabled. It is rebound on each button click.
        Grid_2 has DataViewState disabled and filtering enabled. The DataSource is saved to a session variable and rebound during Page_Load. If the user clicks the button, and new DataSet is retrieved, set as the DataSource and then saved to the session variable for next postback.
        I know I should not call ClearDataSource() during Page_Load as that will clear and selected cells on postback. Should I be calling ClearDataSource() during button click before binding the new DataSet?
        // Convergence Waves
        DataSet waves = Common.GetDataSetSQL("EXEC [dbo].[GetAppWaves] 'LIST', '" + sSite + "'");
        WebDataGridConvergenceWaves.DataSource = waves;
        WebDataGridConvergenceWaves.DataBind();
        // Vertical/Regional/DPTs
        DataSet apps = Common.GetDataSetSQL("EXEC [dbo].[GetDeployableApplications] '" + WebDropDownRegion.SelectedItem.Value + "', '" + Session[HiddenField_SiteOfComputer.Value].ToString() + "'");
        WebDataGridApplications.DataSource = apps;
        WebDataGridApplications.DataBind();
        // Save DataSet to session variable for grid filtering
        Common.SaveDataset(apps, HiddenField_WebDataGridApplicationsDataSet.Value);
        Dana Crosby
        Dana Crosby answered on Mar 12, 2013 3:24 PM
        Feedback?
        [Infragistics] Petar Ivanov
        [Infragistics] Petar Ivanov answered on Mar 12, 2013 3:32 PM
        Hello dc06663,
        Thank you for your replies.
        ClearDataSource should be called in any case when the grid's datasource is being changed (though this can be done just prior to setting the new changed source). It is not required when rebinding the grid to its previous source because it will, as you have noted, clear selection, reset scrollbar positions etc.
        There is a known issue however with clearing the datasource when DataViewState is enabled, which results in the stated exception, which has been resolved in the latest service releases for Volumes 12.1 and 12.2 of NetAdvantage for ASP.NET. I would therefore suggest upgrading your product version or installing the latest SR for 12.1 or 12.2 in order to avoid this exception.
        Please do not hesitate to contact me if you have any questions.
        Dana Crosby
        Dana Crosby answered on Mar 12, 2013 3:38 PM
        Thanks. I was planning on updating to 20121.2156_SR already. Glad to know this corrects the known issue. I have already ensured .ClearDataSource() was called before binding a "new" DataSet. That is what I thought was correct, but still noticed the exceptions in the ASP.NET log on the production server. I plan to upgrade to 12.2 in the next quarterly release of my application. Thanks again.
        Matthew Parry-Hill
        Matthew Parry-Hill answered on Sep 14, 2015 4:30 PM
        I'm encountering the same exception (The string parameter 'key' cannot be null or empty. Parameter name: key) in 11.1.20111.2238 (latest service release).  Because the exception is unhandled, it's getting caught in global.asax, and users are being directed to the custom error page.  I'm now looking at having to either upgrade Infragistics and deal with all of the testing and issues that will come out of that, or else replace the grid controls.  Please let me know if upgrading to a more recent volume is my only option in terms of upgrading Infragistics.  Please correct me if I'm wrong, but I'm guessing that's the case since 2011 V1 is pretty outdated now and is probably unsupported.  Thank you.
        Matthew Parry-Hill
        Matthew Parry-Hill answered on Sep 15, 2015 7:21 PM
        Please disregard my previous message.  I read the lifecycle policy and see that 2011 V1 is no longer supported.  Thanks!
Pete Sral
10 years, 11 months ago
Feb 12, 2026 8:51 AM
