Design changes in Windows 11
Andreas Mueller
Andreas Mueller asked on Nov 29, 2023 5:06 PM
Hi Infragistics Team,
i just installed the first preview of Windows 11 and had a look an the design changes. Microsoft introduced some new shiny stuff for standard controls like textboxes. They now have a thicker line on bottom which becomes blue if the control gots the focus.
Microsoft also has an update for .NET-Framework where they introduced this changes for the standard .NET WinForms Controls.
I know it is quiet an early stage, but du you already have plans to also upgrade Infragistics Toolsets to fullfill the new design standards for Windows 11. Because currently out app looks quiet ugly on Windows 11. It does not totally fit into the rest of the applications.
Regards
Andreas
    Michael DiFilippo
    Michael DiFilippo answered on Jul 1, 2021 2:48 PM
    Hello Andreas,
    I did a quick test comparison and our UltraTextEditor does not show a line/blue when hovered when using Windows 11 compared to MS. However its too early to tell if our controls will pick up other new OS changes automatically. This difference appears be related to how we draw a border. We haven't started thoroughly testing nor do we have a roadmap yet for Windows 11.
    Our controls should continue to appear as they do in other versions of Windows as demonstrated below. And we will most likely advertise this when Windows 11 launches. Keep in mind we will document new changes that are made to reflect/revert the OS as we see fit when they become available. However I don't expect this sort of development until next year.
    Here is a screenshot of our UltraTextEditor in Windows 11 compared to the MS textbox out of the box in .NET 4.8. It still functions similar to Windows 10.
      Michael DiFilippo
      Michael DiFilippo answered on Jul 1, 2021 3:03 PM
      Note, setting the MS Textbox BorderStyle to FixedSingle will remove the line. So it's a design change to their Fixed3d that uses the line.
      Andreas Mueller
      Andreas Mueller answered on Jul 2, 2021 8:22 PM
      thanks for the response. What I would like to see is that the infragistics control will look like the standard controls with the next version. For us it is not an option to go through the whole application and change the border style of all textboxes to have it look the old way.
      Hope to see that on the roadmap.
      Best regards
      Andreas
        Michael DiFilippo
        Michael DiFilippo answered on Jul 2, 2021 10:14 PM
        If Microsoft decides to stick with this current default design then we may implement ours the same way and you will have to change the border regardless whether you will use ours or the MS text box. It just depends what we deem appropriate. It’s possible we don’t follow MS. But it’s too early to tell, MS might end up changing before RTM Windows 11.
        Hugues Jeannerod
        Hugues Jeannerod answered on Dec 15, 2021 9:36 AM
        Microsoft has released Windows 11 a couple of months ago. I'm not seeing any announcement on your Web site regarding Windows 11 design. When are you planning to provide an updated version of Infragistics?
        Hugues
        Hugues Jeannerod
        Hugues Jeannerod answered on Nov 29, 2023 5:06 PM
        Any update on this please?
Andreas Mueller
2 years, 8 months ago
Feb 16, 2026 9:03 PM
