Infragistics Community Forum / Web / Ignite UI for Angular / RangeError: Maximum call stack size exceeded
Thomas Kleist
Thomas Kleist asked on Sep 10, 2019 7:36 AM
I have this function on my TS file that should update a value of a cell
  public totalSum(t: IGridEditEventArgs) {
const column = this.grid.columnList.find(e => e.index === t.cellID.columnID);
    if (column.header === 'Total') {
        const rabat: number = Number(t.newValue) / Number(t.oldValue) * 100;
      const mmRabat = this.grid.getCellByColumn(t.cellID.rowIndex, 'mmRabat');
mmRabat.update(1);
// this.grid.updateCell(10, t.cellID.rowIndex, ‘mmRabat’);
} else {
this.updateMMRabat(t);
But this is the Error I keep getting
MedieplanToolbarComponent.html:81 ERROR RangeError: Maximum call stack size exceeded
at Array.filter (<anonymous>)
at QueryList.filter (core.js:23826)
at IgxGridComponent.get [as rowList] (igniteui-angular.js:64592)
at IgxGridAPIService.GridBaseAPIService.get_row_by_index (igniteui-angular.js:2157)
at IgxGridAPIService.GridBaseAPIService.get_cell_by_index (igniteui-angular.js:2188)
at IgxGridComponent.IgxGridBaseComponent.getCellByColumn (igniteui-angular.js:66439)
at MedieplanToolbarComponent.updateMMRabat (medieplan-toolbar.component.ts:344)
at MedieplanToolbarComponent.totalSum (medieplan-toolbar.component.ts:338)
at Object.eval [as handleEvent] (MedieplanToolbarComponent.html:81)
at handleEvent (core.js:29238)
    Maya Kirova
    Maya Kirova answered on Sep 5, 2019 7:55 AM
    Hello Thomas,
    Could you share some additional information like:
    • When is this function called? Is it called on a particular Grid event?
    • If possible could you share the grid definition and the logic that triggers the related function (totalSum)?
    • Which version of the igniteui angular package are you currently using?
    If you happen to have a sample that reproduces the issue please feel free to share it so that we can look into it.
     I’m looking forward to your reply.
    Maya Kirova
      Thomas Kleist
      Thomas Kleist answered on Sep 5, 2019 8:55 AM
      Hi Maya
      the error is happening when I it tries to update an cell value
      mmRabat.update(1); if I out comment the mmRabat.update(v) it does not crash  and the action event in the grid is
      (onCellEdit)="totalSum()"
      the version I'm using is
      "igniteui-angular": "^8.1.4",
        Maya Kirova
        Maya Kirova answered on Sep 5, 2019 4:24 PM
        Hello Thomas,
        Thank you for the additional information.
        onCellEdit is an event that is triggered every time a cell is updated (via the API or via the UI). As such calling update() Api (mmRabat.update(1); ) inside it will trigger the onCellEdit event again, creating an infinite loop.
        Please make sure you are not updating the same cell inside the onCellEdit event triggered for it. For example:
                         if (column.field !==  'mmRabat ') {
                        mmRabat.update(1);
        Let me know if that solves your issue.
        Maya Kirova
        Thomas Kleist
        Thomas Kleist answered on Sep 5, 2019 6:29 PM
        I have tried the function that you suggested and I'm still getting an RangeError: Maximum call stack size exceeded exception
        Thomas Kleist
        Thomas Kleist answered on Sep 5, 2019 7:11 PM
        that works but what if I want to update the another cell if I edit the mmRabat column ?
        Thomas Kleist
        Thomas Kleist answered on Sep 6, 2019 4:23 AM
        I made this function because  I want to be able to edit more that one type of column but If I try to edit the mmRabat
        and update the value in the totalPris column I get a cirular reference.  I need to be able to edit more that one type of column
        const field = column.field
        if (field !== 'mmRabat') {
        const procent = (t.oldValue / Number(t.newValue).valueOf()) * 100;
        mmRabat.update(procent);
        this.grid.reflow();
        if (field !== 'totalPris') {
        const mmRabat = this.grid.getCellByColumn(t.cellID.rowIndex, 'totalPris');
        Maya Kirova
        Maya Kirova answered on Sep 9, 2019 8:59 AM
        Hello Thomas,
        Currently the way the code is written will cause an infinite loop since totalPris update will trigger OnCellEdit for mmRabat, which will again trigger update on mmRabat (due to the second if statement), which will trigger the event again.
        Could you explain in more details the behavior you are aiming to achieve? For example, when column X is updated via user interactions, then column Y and Z should update their values based on the new user input value.
        The code for something like this would look like this:
        if (field === 'X') {
        const cellY = this.grid.getCellByColumn(t.cellID.rowIndex, 'Y');
        const cellZ = this.grid.getCellByColumn(t.cellID.rowIndex, 'Z');
        cellY.update(<newValue>);
        cellZ.update(<newValue>);
        Let me know if you are aiming to achieve something similar. If not please explain in more details the desired behavior.
        Maya Kirova
        Thomas Kleist
        Thomas Kleist answered on Sep 9, 2019 7:09 PM
        okay  lets say I have 4 columns A B D and D  in the first case I edit Columns D and update B and D next case I edit Column B and update D
        Maya Kirova
        Maya Kirova answered on Sep 10, 2019 7:36 AM
        Hello Thomas,
        Do you have 2 columns bound to the same field (field D)?  If not could you explain what you mean by 4 columns – A, B, D and D?
        Regarding the first use case: I edit Columns D and update B and D
        Do you mean that when the user edits column D you want to change the values for the same column D and another column B or is this a different column D?
        Maya Kirova
Thomas Kleist
6 years, 5 months ago
Feb 11, 2026 9:42 AM
