Infragistics Community Forum / Web / Ignite UI for jQuery / Cannot call methods on igGrid prior to initialization; attempted to call method 'destroy'
longcat
longcat asked on Feb 4, 2019 10:42 AM
I'm trying out the ignite ui controls. When copy pasting the nestedsplitter.html example from your site, i get the following javascript error when i try to select a node in the tree:
Uncaught Error: cannot call methods on igGrid prior to initialization; attempted to call method 'destroy'
I have tried with versions  jquery >= 1.9. The version of the ignite ui im using is 13.1.20131.2143
    [Infragistics] Petar Ivanov
    [Infragistics] Petar Ivanov answered on Oct 1, 2013 11:39 AM
    Hi Longcat,
    In order to check whether the igGrid has been initialized I would suggest using jQuery'sdatafunction as such:
    if ($("#gridTarget").data("igGrid") !=null) {
         //do something
    Please note that this approach may also be applied to other components in the Ignite UI suite.
      Edwin Stephenraj
      Edwin Stephenraj answered on May 7, 2014 12:00 AM
      I am using filter using Javascript and getting following error:
      Error: "cannot call methods on igGridFiltering prior to initialization; attempted to call method 'filter'"
      1) grid already refreshed with data (loaded)
      2) applying the filter programmatically
      function applyFilter() {
      var component = $("#Component").val();
      var attKey = $("#AttributeKey").val();
      var attValue = $("#AttributeValue").val();
      debugger;
      $("#grid").igGridFiltering('filter', ([
      {fieldName: "ComponentDesc", expr: component, cond: "contains"},
      {fieldName: "AttributeDesc", expr: attKey, cond: "contains"},
      {fieldName: "CategoryDesc", expr: attValue, cond: "contains"}
      help is much appreciated.
      Stephen Elms
      Stephen Elms answered on Aug 31, 2015 5:12 PM
      Peter,
      I tried as you suggested, but I am still receiving the "prior to initialization" error?
      <script>function lstSourceCharacteristicValuesSearch() {
      var x = document.getElementById("sbSourceCharacteristicValues").value;
      if($("#lstSourceCharacteristicValues_table").data("igGrid")!=null) {
      $("#lstSourceCharacteristicValues_table").igGridFiltering("destroy");
      $("#lstSourceCharacteristicValues_table").igGridFiltering("filter", ([{fieldName: "lookup_display", expr: x, cond: "contains"}]));
      }</script><div id="sbSourceCharacteristicValueslstSourceCharacteristicValues" style="position:abosolute; left:50px; top:625px; width:400px; height:48px; z-index:4;" class="SearchBox"><input type="text" id="sbSourceCharacteristicValues" onkeyup="lstSourceCharacteristicValuesSearch()"></div></div>
      </div>
      Edward John
      Edward John answered on Nov 19, 2016 6:30 PM
      hey is this possible to call method after infragistic load
        Deyan Kamburov
        Deyan Kamburov answered on Nov 21, 2016 12:05 PM
        Hey Edward,
        All of the IgniteUI widgets have the rendered event, you can bind to it to make sure that the widget is loaded and rendered, before interacting with it.
        Serge Lepouttre
        Serge Lepouttre answered on Feb 4, 2019 10:42 AM
        I have exactly the same problem. When I catch the rendered event and try to call igGridUpdating(X), I'm always getting "cannot call methods on igGridFiltering prior to initialization; attempted to call method X"
        Example:
        rendered: function(evt, ui) {
                        var editing = grid.igGridUpdating("isEditing");
        When I place a breakpoint at "var editing", I'm hitting the breakpoint and I'm always getting "Uncaught Error: cannot call methods on igGridUpdating prior to initialization; attempted to call method 'isEditing'"
        dataSource is JSON data and showing properly in the grid. I can perfectly edit, delete, save,… But every call on igGridUpdating is failing.
longcat
7 years, 7 months ago
Feb 16, 2026 9:32 PM
