Infragistics Community Forum / Web / Ignite UI for Angular / How to merge multiple cells using (igxgrid) in angular
krishna gawai
krishna gawai asked on Aug 4, 2022 8:03 AM
I have to merge multiple Column’s cells based on some condition (Basically on Time).
which is showing dynamic data
    krishna gawai
    krishna gawai answered on Aug 3, 2022 7:26 AM
       Here I am passing dummy image.
      Riva Ivanova
      Riva Ivanova answered on Aug 3, 2022 10:19 AM
      I have been looking into your question and the provided screenshot, however, I need to ask for some additional information.
      1. Based on the provided screenshot, do you require the cells in the columns which are blurred to be merged, or this should be done for the cells in any of the DATE/DAY/TIME columns?
      2. Could you please clarify what do you refer to with “showing dynamic data”? Does this data refer to any of the DATE/DAY/TIME columns?
      3. Do you require, for example, the cells in the DATE column to be merged based on their values and at some point, if the data for these cells changes – the merging should be redone using the new values?
      Answering these questions would be highly appreciated and extremely helpful in providing you with a solution as soon as possible.
      Additionally, I believe you will find our Multi-Row Layout topic very helpful as this feature allows splitting data into multiple visible rows. In this topic you can find multiple samples and API References as well.
      However, if none of these samples is an accurate demonstration of what you are trying to achieve, could you please provide me with a small sample, which replicates your data structure, filled with some test records and the desired igx-grid functionalities so that I will be able to investigate it further.
      Thank you very much for your cooperation on this matter.
      Riva Ivanova
        krishna gawai
        krishna gawai answered on Aug 3, 2022 10:28 AM
        Hello Riva,
        Yes based  on the time I need to merged cells which is blurred and also DATE/ DAY/ TIME should also merge.
        (like if program is 1 hour's then 2 cells and if 2 hour's then 4 cells should merge)
        Riva Ivanova
        Riva Ivanova answered on Aug 4, 2022 8:03 AM
        Hello Krishna,
        Thank you for following up!
        After further investigating this matter, I am under the impression that you require merging cells from separate records based on a certain condition, however, what I could say is that, at this point, we do not provide this functionality out of the box. It is considered a feature request and should be logged in our GitHub repository.
        Additionally, I have noticed that such a request has already been logged here, and what I could suggest in order to have this feature implemented in any of our future releases, is to explain the context in which this feature would be used and why it is needed as well as anything that would prevent you from accomplishing this today. You can even add screenshots to build a stronger case. Also, it would be great and extremely helpful if you could provide the answers to the questions from this conversation as well.
        Please let me know if you need any further assistance.
        Riva Ivanova
krishna gawai
4 years, 1 month ago
Aug 4, 2022 8:03 AM
Feb 20, 2026 12:19 PM
