Hi there… i am still using old version Infragistics ASP.Net 2015.1 via MVC on VS 2015…
sample:
settings.ColumnSetting().ColumnKey("CID").Required(false).ReadOnly(false)
.EditorType(ColumnEditorType.Combo)
.ComboEditorOptions(co => co.DataSource(companies).ID("CIDCombo").ValueKey("CO").TextKey("CO").Mode(ComboMode.DropDown).EnableClearButton(false)
.MultiSelectionSettings(ms => ms.Enabled(true).ShowCheckBoxes(true).ItemSeparator(","))
.DropDownOrientation(ComboDropDownOrientation.Bottom)
so, my db-table field CID (comma delimited string values) would require to bind to this combo editor with multi selection capability… however, i cannot get the API required per your javascript sample… please, advise if it's because either the version I have is too old or because I might be missing any references… if you have a sample for my situation i will appreciate it…
Note: I want to stick to the MVC way if possible…
