I tried your suggestion.
In this case chart displays labels of wrong column (instead of column 0 it uses labels from column 1).
By the way is there a possibility to tell chart to plot just say first 100 rows from table?
DataTable tbl = new DataTable();
tbl.Columns.Add("Age",typeof(int));
tbl.Columns.Add("Value",typeof(double ));
int lcount = 300;
for( int i = 1; i<lcount; i++)
DataRow r= tbl.NewRow();
r["Age"]=i; r["Value"]=Math.Sin(3.14*i/100);
tbl.Rows.Add( r);
dgForecasts.DataSource = tbl;
chartForecasts.DataSource = tbl;
//chartForecasts.Axis.X.TickmarkStyle = Infragistics.UltraChart.Shared.Styles.AxisTickStyle.Percentage;
//chartForecasts.Axis.X.TickmarkPercentage = 10;
chartForecasts.Axis.X.Labels.Layout.Behavior =
Infragistics.UltraChart.Shared.Styles.AxisLabelLayoutBehaviors.None;
//chartForecasts.Axis.X.Labels.Layout.Behavior =
// Infragistics.UltraChart.Shared.Styles.AxisLabelLayoutBehaviors.Auto;
Infragistics.UltraChart.Shared.Styles.AxisTickStyle.Smart;
chartForecasts.Data.RowLabelsColumn = 0;
chartForecasts.Data.UseRowLabelsColumn = true;
chartForecasts.DataBind();
