Jeff Staddon
Jeff Staddon answered on Jan 29, 2015 5:56 PM
The following worked for me:
MyComboBox.DisplayLayout.Bands(0).ColHeadersVisible = False
Jeff Staddon
Jeff Staddon answered on Feb 3, 2009 3:48 PM
Finally got it to work using the following code:
Dim tempValue As String = myPreviousValue 'changes to the object loose the selected row–save it off and restore later
MyUltraCombo.DataSource = queryDS.Tables(0) 'load the new data
'Restore the previous selection
If tempValue <> "" Then
    For Each row As Infragistics.Win.UltraWinGrid.UltraGridRow In MyUltraCombo.Rows
        If row.Cells(0).Value.ToString = tempValue Then
            MyUltraCombo.SelectedRow = row
        End If
    Next
End If
Jeff Staddon
Jeff Staddon answered on Feb 2, 2009 3:57 PM
Makes sense.  What method would I use to set it?
Jeff Staddon
Jeff Staddon answered on Jan 30, 2009 9:03 PM
I'm running into a wierd senario.  When I set the text property it works–but it also clears all the values out of the drop-down list.  Seems I can either set the value, or have a drop-down list but not both. 🙁
