liran pere
liran pere answered on Jul 8, 2018 9:47 AM
hi ,
well i tested it again on my machine ( the first tests were at the QA env. so i need to check what is installed or not on it)
i got it to work ( with the samples and our application) so it does not freeze.
i still got an issue with editor button ( button in the ButtonRight collection of the cell)
the UFT does not recognize it , do i need to write a code in the action tab in the UFT to simulate a click on it ?
can you give me an example as how to do so ( working with editor button i mean)
liran pere
liran pere answered on Jul 3, 2018 8:55 AM
so i download a trial version of HP just to check (14.03 )
it seem to work , so there might be a issue with 12.01 and Infragistics 14.01
issues that we did  found were
a problem with editor button that under the test no action was record for selection or clicking the button.
and sometime dialog windows or message boxs that the test did not record property and failed because of that.
again we have HP 12.01 so i rather use that and not update it yet, ( might not be possible)
liran pere
liran pere answered on Jul 3, 2018 7:01 AM
Hi Michael,
thanks for the quick response,
in the application we are using 14.01 (for now)
we have tried the samples but all of them froze during record  (not responding)
both under CLR4 and version free ( changed it under Version Utility before opening the UFT)
so now the question is does the version of UFT compatible with 14.01 ( UFT version is 12.01 – that is what we have)
or is it something else you can think of to help us .
Liran
